SOURCE: ear pad replacement instructions for Sony MDR-V6 Headphones
Hello to all who have exhausted all avenues seeking instructions on how to remove and replace Ear Pads on Sony MDR-V6 Headphones.... All that is required is a little patience maybe some fingernails... The Pads simply slip on and off by pinching ends of cuff that is nearest the plastic backing of The Headphones by pulling them from their seat/flange .. i found it easiest to just roll the cuff off using my thumb w/rolling motion away from the plastic backing/housing of the headphones.. no tools required.. they are installed exactally like one would place a tire on a rim.. exact same motion is required as when removing a tire.. i can give no better illustruction than comparrison to tire removal and replacement. Be careful to make sure one end in completely set deeply into one side before attempting to pull opposing side over its side/flange..start on top and work way around to bottom or vise versa.. To get an idea of what you are attempting to do take a close look at new headphone pad rear and you will see the small flap of leather on rear .. there is a small overlap that fits perfectly over the flange.. dont try to force it as you may tear them...
SOURCE: Sony MDR-V500 headphones: Cushions falling apart!
You can go to Radio Shack and find some that fit. Although Sony does not sell them as they woudl ofcourse want you to purchase new ones you can buy third party cushions that fit.
SOURCE: How to Rewire Sony MDR-7506 headphones
Okay, cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
SOURCE: Where can I purchase replacement ear pads for the
If you click my name it will take you to a tip of mine on headphones. At the bottom of it is a link that will help you solve your problem.
SOURCE: I need replacement ear pads
Check out My tip on headphones, at the bottom of it you will find a link to a place that should have them. Just click my user name to find the tip.
