Question about GE 28112EE2 Cordless Phone
Date and time change
How do you change date and time?
  • geeastman Nov 23, 2008
    Cannot change date. Where can I get a manual?
I found the manual for this GE 28112EE2 phone at this website
http://pdf.smithgear.com/28112EE2_IB.pdf
Posted on Dec 12, 2008
Set clock on computer
  1. Press the Windows key on your keyboard to display the taskbar if it isn't visible.The Windows key has the Windows logo on it.
  2. Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu.
    The Date and Time dialog box appears.
  3. Click the Change Date and Time button.
    The Date and Time Settings dialog box appears.
  4. Enter a new time in the Time field.
    You can also use the up and down arrows next to that field to change the time.
  5. If you wish, click on a new date in the calendar display and then click OK.
    You can also change the time zone, if necessary.
  6. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
    If you don't want your computer to adjust for Daylight Saving Time, click Change Time Zone and click the Automatically Adjust Clock for Daylight Saving Time check box to turn this feature off.
  7. Click the Change Date and Time button.
  8. Enter a new time in the Time field.
  9. If you wish, click on a new date in the calendar display and then click OK.
  10. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
Jan 20, 2017 | Computers & Internet
Change the date and time
Good day!
1. Point mouse to time and click > change date and time settings > change date and time > continue > select appropriate time and date > OK > apply > OK > DONE.
2. Go to bios settings change date and time > save settings
Mar 28, 2014 | Computers & Internet
Need to change time on my toshiba laptop pc
Windows 7 and below:
Start> Control Panel> Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Windows 8: Start> Type control and control panel will pop-up on the search list, click on that to open control panel>Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Feb 07, 2014 | Toshiba Computers & Internet
DATE -TIME RESET??
What seems to be the problem with the date and time?
If you want to change the date and time settings, then you can click on the time on the bottom right corner of your screen. There you can change the time and date settings.
Or if date and time are always changing whatever you do then you would need to change the CMOS battery of your computer.
David
Jun 10, 2013 | HP Compaq Presario V2000 Notebook
Can't change date or time on my new Pentax K2000
Date/time are set at "first use" or through the tools menu.
Remove the batteries.  Leave the camera overnight, this may be enough to lose the current settings and allow setting new date/time.
Press Menu button.
Press right arrow on the 4-way controller to get the Tools (spanner) highlighted.
Press down arrow to get to date (or time).
Press right arrow
Now set to your preferred format.
If this does not work, try changing another item in the Tools menu.  If that change is not accepted, then it's into the dealer.
Jun 21, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
Change time & date on the victor 1530-5 adding machine
I recently solved this issue with my calculator
Press and hold the time key when the date is dispalyed. When the display flashes enter the date as a six digit date (example 110608 for November 6, 2008) Time needs to be entered in military time when changing time.
Aug 15, 2008 | Office Equipment & Supplies
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
System date and time does not change on my laptop
What do you mean it "does not change"? Have you tried to change them using the Control Panel applet, or by clicking on the time in the taskbar and trying to change it there? Or, do you mean the date and time is not incrementing at all while watching the time?
Mar 23, 2008 | Computers & Internet
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Jan 07, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
GE 28112EE2 Cordless Phone Logo
185 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
