Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
No power?? hi can any one help,my hotpoint wd63 washer dryer has died,its only 4 years old. for the past month or so its been not starting properly after door is shut it didnt turn on firsr time and would have to keep trying it then last week it stopped half way through and wouldnt do anything.it appears to have no power,ive changed the door interlock switch and checked fuse,ive seen other hotpoints on ebay with same fault ! can any 1 help .
  • tbush11 Nov 14, 2008
    No power at all. Plug it in and nothing at all happens. I have no wiring or other  diagrams of where things are so am operating blindly. How do I check the door lock switch and the timer contacts?
    Problem Solver:
  • 5 Answers
It's more than likely its the door lock, if not check the timer contacts on the top front connection block, if they have blown it will need a timer & door lock
Posted on Nov 03, 2008
Water remains in the tub after spin cycle
Sounds to me like the Water Pump is bad. Hopefully if your machine is less than a year old you can get it fixed for free, if you bought it new it will have a 12 month warranty on it. If not you can always buy the manual for your washer and try to fix it yourself.
May 15, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD63 Random Fault
if the drum will not turn it may be the motor brushes
Sep 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD63
Sometimes the door lock doesnt engage properly! This could be the cause, give door a good slam shut. Hope this is of help.
Jun 16, 2008 | Hotpoint Aquarius WD63 Front Load...
WD63 washer dryer
your inlet valve is not opening properly and needs to be replaced. this is quite a common fault with inlet valves
Mar 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Wd63 does it have a filter to empty for the dryer!?!
Hi there sarah
The hotpoint washer dyrer does not have a filter for fluff
100%
Need any other help dont hesitate to ask
Jan 13, 2008 | Hotpoint Aquarius WD63 Front Load...
WD440 programme m
This sounds like a faulty pcb and/or inlet valve. see links for prices.
meatballs77 - If you have warranty (the machine is less than 1 year old which yours is) or paid for extended cover then call hotpoint to replace... Hotpoint should be able to fix this - this should be free. call 0870 4422 510
Rememer parts are free up to five years - but there is a £90 callout fee after the first year.(unless you extend the full warranty)
Nov 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Jan 06, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
177 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
