Question about HP DeskJet 1600cn InkJet Printer
HP DeskJet 1600cn doesn't print color
I have replaced all the ink cartridges and the black does a beautiful job but there is no color. At all! I can't even get it to print a self test page using color. (I did this once kind of accidentally and now can't seem to remember exactly how I did it.) It prints a test page but only info and in monochrome. Manuals or any real info on this printer seem to be nearly inattainable. Thanks!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Hi Vern,
Check the print driver setting for an option that may be checked "print monochrome", remove this check mark.
Posted on Aug 11, 2017
  • 27 Answers
SOURCE: HP Photosmart 8450 Ink Level Indicator
replace the ink cartridges
Posted on May 31, 2008
SOURCE: HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Posted on Jun 16, 2009
tommya300
  • 724 Answers
SOURCE: HP Deskjet 5740 printer won't print in color.
did you check the printer properties on the computer side?
take off of gray scale I believe this may be the reason
Posted on Jul 31, 2009
  • 19 Answers
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 24, 2009
michaelshaun
  • 126 Answers
SOURCE: My HP Deskjet F4580 won't print. Print jobs go
plaese folloW the instrutoion mention from the below URL and try
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00843712&cc=us&lc=en&dlc=en&product=3944758
still dose not work then try this url mention from the bellow
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669384&cc=us&lc=en&dlc=en&product=3944758
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321436&cc=us&lc=en&dlc=en&product=3944758
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01361419&cc=us&lc=en&dlc=en&product=3944758
if still the issue is not resolve then contact hp tollfree number 1800-474-6836 they will replaced the printer if the warranty period is there.
hope this should resolve your problem
thanks
regards
HAMID
Posted on Mar 01, 2010
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
Sep 03, 2013 | HP Office Equipment & Supplies
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
My desk jet 3320 printer do not print black
Are you sure there is enough level on the black ink cartridge.. if does try to do "print head clean up" if doesn't fix the problem consider to replace the black ink cartridge
Aug 31, 2012 | HP DeskJet 3320 InkJet Printer
HP 5150 Deskjet -- black printing abruptly stopped. Prints appear with color but no black. Switching black cartridges doesn't help. Clean print heads operation doesn't help. Switching computers...
There are very few things you can do, other than what you have aleady done.
I would recommend a decision on how much the unit cost and how long you have used the
printer vrs. what HP or a local authorized service center would charge to repair it.
If you have refilled ink cartridges, this is problem that can arise due to ink drying on the
print head as the black cartridge is use the most.
Aug 06, 2011 | HP DeskJet 5150 InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
I tried to print a photo card on my hp deskjet
yes, both cartridges are used for all print jobs, color or not.
Jun 14, 2009 | Office Equipment & Supplies
Color is wrong
Have you tried replacing the cartridges? Some programs such as Adobe Reader will generate a "black" equivalent from the color cartridge. In this case, if the color cartridge is low in red, the outcome will be blue. This would signify that the color cartridge needs to be replaced. HP supplied a utility program for the HP6122 to detect and report ink levels. If you have this utility, check the levels. The utility will only work if the computer is directly connected to the printer -- not thru a print server. If you don't have the utility, you should be able to get it at the HP website http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=83028&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=88749
You might find that both the black and the color cartridges are out of ink. Some print drivers can detect when the black cartridge is empty, then attempts to print a black equivalent using the color cartridge.
Mar 16, 2009 | HP DeskJet 6122 InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
HP DeskJet 1600cn InkJet Printer Logo
46 people viewed this question
Clive
Clive
