Question about Combi Centre DX - Mango
Baxi/Potterton wall hung fan assisted combi boiler
The heating works fine but we have no hot water supply.
  • 1 more comment
  • Anonymous Jan 28, 2009
    not geting hot water out of 3 year old wall hung Baxi boiler model Luna 24SI or FI has been problematic all three years but now not good. get no hot water in shower or bathroom but get hot water at kitchen (most of the time, but not always)
  • Steve Smith
    Steve Smith May 11, 2010
    Hi, Please can you tell me the model of your boiler Thanks Steve
  • Rod Davies May 11, 2010
    Tell me about the kitchen hot water - flow rate - low, medium & full when does the water get cold and/or boiler turn off
    If you have the ch on at the same time does this also go off when hot water goes cold, or not
    make sure the pressure shown on boiler guage is about 1 bar
    Problem Solver:
  • 16 Answers
Does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Posted on Aug 17, 2009
  • clive
    clive Nov 21, 2013
    Yes when I open hot water boiler does come on
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
I have a potterton proforma28 boiler can anyone advise how to get hot water back as it seems to have gone off
if you go to the baxi potterton wed site you can down load a manual with fault finding on your boiler as this could be a number of things
Aug 07, 2010 | Heating & Cooling
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Combi Centre DX - Mango Logo
932 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
