Question about HP PSC 1410 All-In-One InkJet Printer
Won't Print, copy or scan
Printing an excel doc. only line show no information on doc, won't copy at all just a plank paper, scan nothing happens
  • tammydill Nov 05, 2008
    i changed the black ink cartridge and now it wont print or copy
  • 39 Answers
Take the cartridge back out and reinstall it just to be on the safe side. If that does not clear up the problem, there is a very strong possibility that you have a faulty cartridge that needs to be replaced (it can be faulty even if it is a new cartridge). - Graye
Posted on Nov 24, 2008
How do i stop my sharp mx 4111n printer from printing with line on the paper
does this happen when printing? or copying? if printing check the fuser, image /drum unit What color is the line replace that image unit, if copying does it happen thru the doc feeder ? if so place on the big glass and make a copy if it goes away the its the doc feeder slit glass that is small glass use by the doc feeder, big glass not used by the doc feeder when copying or scanning
Feb 17, 2015 | Sharp Office Equipment & Supplies
Printing only every other line in Word 2007 doc
Dear pony, it could be because you might have changed your print settings.
You can press CTRL+P to change settings
You might also select the text you want to print and print selected.
You can also format the text by going into formatting options of MS word.
This can be because you've put the number of copies to 2. Thats why its printing again. Change it to default and it should fix your problem
If that has helped you please press 'fixya'
Nov 30, 2007 | Microsoft Office Professional 2007 Full...
I have a black line showing up on the left sized of my paper that goes up and down across the copy. Nothing shows up when I print directly from the computer though. Can't figure out how to fix it.
there is probably some ink, white out or paper dust on the doc feed scanning glass or copy glass. Clean all glass with a cloth dampened with water, or isopropyl alcohol works best. This happens to my customers all the time.
Sep 16, 2011 | Brother MFC-7440N Laser Printer
When I print 1 copy from my laptop, it will not stop printing many copies and I tried to copy a photo and there are horizontal lines on the copy. Jacques
The numbers of copies your laptop print out is set in your printer software.
You did probably forget to change the numbers to 1 (one copy).
If you use normal print paper for photos, it will almost always make horizontal lines.
Use photo print paper instead, then it won't happen.
It could also be that your print cartridges need a nozzle cleaning.
Normally your printer software has a mode to this.
Hope this will help you
Regards
Aug 29, 2011 | Kodak Cameras
Printer is only half printing doc on each line, have done test page, very faint, aligned ink, clean cartridges, all with top v faint and bottom dark ink, new cartridge last fri and was working well,...
Open the rear of the printer and make sure theres no paper jam or broken parts.
Try printing a document with the rear of the printer open and watch to see if anything out of the ordinary happens.
Mar 01, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Jun 05, 2009 | Lexmark X6570 InkJet Printer
Hp director shows 2 icons.
just adjust the cable of the printer at the back of your desktop..
Jan 21, 2009 | HP Compaq dc5700 Microtower - Free Flat...
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Sep 23, 2008 | HP LaserJet 4 plus Printer
Officejet 6110 all in one - printing problem with Mac Os X 10.5
I suspect this is not the printer problem. The problem may be the operating system issue. (Memory management)
Regards
Rafique
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Ms word 2007 docs print every other line
This seems like a print driver problem. You may have to get an updated driver for your printer for Msoffice 2007.
Sean
HP PSC 1410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
