Question about Coleman Electrical Supplies
Coleman powermate 2500
Ran fine for 5 minutes the no output any suggestion
  • Loringh
    Loringh May 11, 2010
    I'm not a generator repair man, but I am a retired electrical engineer so a few questions before jumping to any conclusions.
    Are the output(s) fused or circuit breakers.?
    I assume from the model number that the output is 2500 watts.
    Is there an output volt meter? If there is, does it show an output voltage when there is no load connected to the generator.
    Finally, what kind of a load do you normally connect to the generator
    Get back to me and perhaps we can get you up and running.
    Loringh
    Prodigy:
    An expert who has answered 500 questions.
  • Coleman Expert
  • 573 Answers
Check capacitors and rotor rings
Posted on Nov 23, 2013
FRANKSFIXIT
  • 72 Answers
SOURCE: Coleman Powermate 6250
My answer:
This a fairly common problem & easy fix with the Powermates, and other Gensets in the same class - made in you know where - China.
I seriously doubt if the Ignition Coil had anything to do with the failure of the KILL switch, as by how it's wired in the Genset circuit unless maybe you failed to fully set it to the ON position, and then in that case you may have had some "arc over" internally at that switch contact point to Gnd - prematurely causing a bit of engine surging - as that like which happens just before an engine runs out of gas.
If your Genset has a 3-wire connector harness coming off that ON/OFF switch then most likely there are only 3 wires connected to the back of that switch. One single wire (most likely GRN in color) goes to an/the Engine Block GROUND bolt somewhere - easy to follow.
The other 2 wires will be the same color (every Genset is a bit different so my schematic only says they are #18 with no color stated - possibly WHT though ??), and one of those 2 wires goes to the #1 pin of that 3-wire harness connector, which in turn is WHT in color on the other side of that 3-wire harness connector pin #1, and goes back to the Control Board inside the Front Panel Box. The other #18 switch wire goes to the Ignition Coil Primary side. Lets hope it's just a bad switch and not a bad Control Board.
Most likely the switch contacts inside just burned out from heat breakdown, as when you go to shut off the Genset - by turning it to OFF - the switch has to take the Ignition Coil Primary voltage/current and basically SHORTS it to Ground thus collapsing the Ignition Coil by robbing the Primary excitation voltage. It's bound to fail if it's a "cheap switch design" to begin with. AND - we all know about cheap Made in China stuff now don't we?
Just so you know - you are not the only one in this same Genset boat - as there are tons of people out there with far worse Powermate problems then just a simple switch problem like you have there. Count your blessings!
You are right about Powermate being out of business though, but not all hope is lost there either when you read everything farther below - as to factory service and parts for your Genset.
I know it's a little long, but the info farther below may be of future help to you later down the road - so copy and print it out for later reference just in case you have other Powermate Genset issues or this site goes down as well....hahahaha.....just kidding.
If you choose to contact the PRAMAC people about getting a new switch, and repairing the Genset yourself here are a couple options for you. If their factory replacement part is outrageously high in price - then you have another option.
If you are handy with a good soldering iron and some good 60/40 Kester solder and acid flux all you have to get is a good ON-OFF single-pole single-throw (only 2 wire connection points for the wires) toggle switch rated at 120 VAC or 12-24 VDC, and at least 10-15 amps rated, and just do it yourself. $5 part worst case!!
DO NOT use a Momentary switch type - as then someone could start the Genset inadvertently - esp if you have smaller kids around!!
Just make sure you get a good solder connection on the wires and the switch tabs, and make sure you tin both the wires and the switch tabs first to get good results. If the switch doesn't fit the old hole perfectly you may have to do a bit of modification work there.
Sorry - I can't help you out there. Make sure you mark the switch as to ON & OFF - unless you find one with a metal ON-OFF backplate like some come with - as there is no right or wrong way here. It's either one way or the other depending on how you mount the switch to personal preference. Right - Left or Up - Down.
Test the switch first before final mounting by firing the Gennie in whichever is the ON position so you know which is which, and make sure it kills the Gennie when you flip the switch in the opposite direction. That's is all there is to it. You're done!!
Hopefully like I said before the Ignition Coil is OK and so to is the Control Board otherwise I know I'll be hearing back from you soon.
Please post me a reply as to finding this solution being the best resolve to your Genset problem there by following my recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Posted on Sep 09, 2008
  • 18 Answers
SOURCE: coleman powermate 6250 mod# PM0525303
The most common problem is the capacitors blowing. This is the round (usually white in colour) barrell shaped device usually found in the end cap of the alternator. It will have two wires attatched to two of four pins. I would advise that you check the voltage at the end of the alternator first to eliminate a wiring problem. The capacitor can only be tested with the correct equipment but changing it should solve your problem- 75% sure.
Posted on Sep 18, 2008
knotbeerdan
  • 413 Answers
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Posted on Dec 19, 2008
protek480
  • 1723 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
protek480
  • 1723 Answers
SOURCE: No Power Output
Okay, this is going to sound kind of hard but you can do it...you need to flash the field and try to get some 'excitation' back to the windings. It's a bit of a deal but here's how:
With gen not running, plug the battery charge plug in to the charger output and you need to reverse the leads at the battery. Hook the BLACK to the positive post. Then, just touch the red to the negative terminal for a second or two. That's it!
Then...start gen and check output. If it just needed a flash, that will do it, I'm serious!
Posted on Aug 06, 2009
My coleman 2500 powermate generater leak from top of carburater, help
The carburetor needs to be rebuilt - the float valve is stuck open.
Jul 05, 2014 | Coleman Powermate Portable Generator...
Where is the fuel shut off valve on a coleman powermate 2500
follow fuel line from fuel tank to the carb if you dont find it it probably does not have one
Sep 04, 2010 | Coleman Powermate Proforce 2500 Generator
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
Jan 18, 2010 | Coleman Sport 1850 Generator
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
Jun 25, 2009 | Karcher 2500 PSI Pressure Washer
Coleman 5000 generater-no AC output
Try replacing the capacitor. You can buy it from http://www.jackssmallengines.com/do_it_home.html. When you pull off the power end of the generator look at the diodes also. If they look toasted replace them as well
Jan 09, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
122 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
