Question about GE JVM1860 Microwave Oven
GE Microwave Oven JVM1860SF001 - Noisy fan
It seems like there is a exhaust fan adjacent to the light bulb in the ceiling of the microwave that is making rattling noise. Since microwave is working except for the noise, is there anything that can check/clean-up to get rid of the noise. I tried to remove the circular ceramic plate in the ceiling of the M/W next to light bulb by twisting counter-clockwise; I was hesitant to apply forece on the button to disengage the pin/button. 1) Should I depress the button to turn to remove the plate. 2) Could the issue be with exhaust fan 3) If so, how to access/fix it. Thanks for your response in advance.
  • 2 more comments
  • smirth Nov 04, 2008
    Update - I figured out the issue with my microwave oven. Problem is with the Stirrer Drive Motor a.k.a. Synchronous Motor ST-16FE(EX73MRAA) - OEM part # WB26X100037. GE Parts Sales wants $86.00 for it to ship the motor; I am thinking of other options...
  • smirth Nov 09, 2008
    I've already got it from eBay. Thanks!
  • zurgdawg Nov 28, 2008
    There must be something in the air as I just had this same issue happen to me!
    Questions:
    - Were either of the 2 substitutes acceptable?
    - What exactly does this motor do? It doesn't turn the tray, I assume it is turning something 'internal' on the ceiling of the microwave?
    - Were you able to replace the motor without having to take the entire microwave out and remove the top? If I had an L screwdriver, I could probably get it in there, but didnt know if the motor would make it out.
    Thanks!
  • Carlos May 02, 2009
    I had the same issue. Follow the steps stated above and you will fix it. Thanks for the post and the links.
The fix is that the magnet inside the bottom of the motor eventually drops enough as it spins(plastic hat-shaped piece under it wears/crushes down) to rub on the bottom of it, where it is metal, causing the noise. You can easily remedy this by taking apart the motor, pulling out the magnet and plastic booster piece under it, placing a thin washer on the bottom to boost them up a bit, then reassembling. Problem solved and no need to buy some overpriced part and fill up the landfills with perfectly good equip!
Posted on Apr 11, 2010
  • dgc_charlott Aug 30, 2010
    I just tried lh8getnripd's solution and so far, so good. Like plan2much, the motor is used on the ceiling in my microwave, an 8 year old GE Spacemaker XL1800. A few years ago I replaced a motor that looked just like this that drove the turntable. It was easy to get to the motor . . . less than 5 minutes. It was a little harder to actually get the motor out. The two tiny screws holding it in place are easily reachable, but there is not adequate room for a screw driver. I was able to get them loose with a small adjustable wrench and a small phillips head screwdriver bit. Once loose, I could get them out with my fingers. I used a small screwdriver to pry the motor apart and used plan2much's suggestion to cut a washer out of plastic packaging. I was able to snap the motor back together relatively easily. When I installed it back in the microwave, the noise stopped and all appears to be working well.
  • GE Master
  • 9,042 Answers
If yours has a square-shaped shaft, it would be part # WB26X10037. That would run $37.23 plus shipping here.
If yours has a D-shaped shaft, it would be part # WB26X10038. That would run $29.28 plus shipping here.
Does that sound better? *grin*
Posted on Nov 09, 2008
I used this suggestion to fix an ST-16FE (EX73SAAA3) motor (D-shaped shaft)that turns the platter in a hotpoint microwave. For this though I noticed that it wasn't that the plastic "hat" was crushed. It was that the plastic shaft, with "hats" on both sides to hold the magnet had separated which essentially separated the motor from the shaft. There was still resistance so the platter still moved and the case did show signs of ware from the magnet. I superglued the hats back on the magnet and added the disk and all is quiet. Different motor but your suggestion still worked Thanks for the post.
Posted on Aug 04, 2012
Thanks lh8getnripd. I used cut up a clear hard plastic package covering to sereve as a thin washer. The metial washers I had were far too thick and maybe the fact that they are magentic doesn't help. Also on my ST-16FE (EX73MRAA) was used for some sort of rotorary mircowave disperser on ceiling of the internal chamber, not as a rotary table wich made the shaft pointing down not up. The fix still works so the magnetic must be pulled up during operation. My micromave lasted 9 years before the noise started.
Posted on Jun 05, 2010
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
Under microwave lights stoped working for GE JVM1660SB 005
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 18, 2011 | GE JVM1665DNSS Microwave Oven
How do you change the drive motor for the turntable in the jvm1860sf001 microhood
Very easy - remove the lower plate on the bottom where the fan and lights are. 3 screws across the front, two on each side. This plate will come down, and the motor will be right there on the bottom of the cavity directly below the turntable coupling.
Go to www.microwaveglasstrays.com to find the motor.
Jan 18, 2010 | GE JVM1650 1000 Watts Microwave Oven
Ge spacer saver microwave lght and fan
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 19, 2008 | GE JVM1440 Microwave Oven
GE XL1800 Microwave Problem
First of all, unplug the oven when changing the bulbs, and use good quality bulbs form a home center, as opposed to dollar store or grocery store subs.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Lighting Problem
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Mar 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1860 Microwave Oven Logo
3,019 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
