Question about Singer CE-100 Futura Computerized Sewing Machine
Needle wont pick up the bobbin thread
When the needle cycles it will not pick up the bobbin thread to make a stitch.I suspect the timing has slipped but am not sure how to reset it.
  • 6 more comments
  • Pauline25 Feb 10, 2008
    I change the needle, Iclean the machine and put oil in it
    I try to change the tension my mavhine is a Singer Fashion Mode model 237 it is an old one
    Pl
  • Anonymous Mar 14, 2008
    I am having the same problem.  The needle will not p/u the bobbin thread!!!!!  I am so frustrated b/c I was in the middle of a project! I hope this isn't expensive to fix.
  • cripsy May 05, 2008
    so where's the answer or recommendation what to do when the thread from the bobbin won't pick up?
  • Anonymous Sep 13, 2008
    my singer will not pick up bobbin thread,either. have cleaned and changed needles and also ord ered a new bobbin holder and it still doest work.HELP I have a model 9020
    chic@cinci.rr.com
  • pjmanning Mar 14, 2009
    Help, my daughter was in the middle of a school projectwhen all of a sudden she started having problems.It only seems to happen while she was trying to embroider. Regular stitching works fine.
  • Ruth
    Ruth Dec 02, 2013
    I have a brand new machine
  • Anonymous Mar 20, 2014
    Needle not picking up bobbin thread.
  • Anonymous Mar 24, 2014
    when you lower the needle it does not pick up the thread from the bobbin
Can not do by yourself. Mine did the same thing after just having it 3 weeks and I had to take in to authorized Singer Dealer to repair. Now without machine for several weeks and probaly out alot of money for repair. Should have got a Brother!! Hope you have better luck than me.
Posted on Oct 10, 2007
My stitch wont stay in the fabric what am i doin wrong
needle thread tension worng
no thread in the bobbin
neeld /hook timing is wrong
May 14, 2017 | Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 10, 2016 | Sewing Machines
Machine wont sew. Misses stitches
check for problems in the bobbin winding, ( in the wrong way so that the thread is not coming out correctly)
top thread tension too tight or too loose
vary the thread tension to see when it improves on a waste test sew
Aug 21, 2016 | Sewing Machines
The needle is not picking up the lower thread, I have cleaned the machine but the bobbin is not being picked up
Doesn't pick up bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Warped needle
8. Warped bobbin
9. Also could be a timing problem
Feb 10, 2016 | Sewing Machines
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Sewing machine won pick up bobbin thread hook timing fix
Feb 06, 2016 | Sewing Machines
Does any one know anything about a sewing machine model 217-APP no 457. Think it may be a singer, have just found it in late mother-in-laws shed. It won't pick up the bobbin thread but runs ok
not picking up the bobbin thread is an indication of needle / hook timing
thread tension problems appear as a mess of stitches under the cloth
the timing can be checked by having the needle full down and the hook of the bobbin case should be at the needle just above the eye of the needle
if it is too early or late then it is not in position to get the thread
May 13, 2015 | Sewing Machines
How do I thread the 960 Bernina Bobbin?
I'm assuming you have a front loading bobbin. Look at your bobbin. Hold it so the thread is falling down from the top to the right side. Slip it straight in to your bobbin case, and pull up through the slit, until it snaps in through the side clip.
Generally, if you are missing stitches, the hook isn't picking up the thread from the needle, and you will need to take it in for service at a Bernina dealer.
Mar 03, 2015 | Bernina Sewing Machines
The thread on the needle of my Elna sewing machine wont pick up the thread on the bobbin and bring it up?
Is your needle in backwards, always the flat shank to the back, make sure it is in all the way up in its housing too. Is it a new needle, not blunt, bent or hooked on the tip, sometimes we don't notice butthe needle is very important and should be changed every 4-6 hours sewing time. The shuttle hook goes around and catches the upper thread during stitch-formation, timing of these two parts is crucial so if this is a machine that has been damaged or do you suspect the timing is out perhaps. If so, technician time.
Aug 22, 2012 | Elna Sewing Machines
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Aug 25, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer CE-100 Futura Computerized Sewing Machine Logo
339 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
