Question about Sharp 32R-S50 32" TV
Same channel on all channels
Sometimes when I turn on my Tv.. all the channels play the same channel. If I turn the TV off, I have just a fuzzy screen... then I try to do easy set up with no success. After a few hours,the TV works fine. I have had my cable/signal checked multiple times with no problems found. Any suggestions? Could this be the TV? Any help would be appreciated.
  • tab Cook Sep 25, 2006
    I am not sure what the tuner is. The picture is clear on all the channels, it is just the same channel. Since yesterday, I have had ESPN on all channels for @ 12 hours. Is this costly to fix if it is the tuner, or should I just buy a new TV. Please help, I am out of solutions. Thanks
    President:
  • 3,130 Answers
Yeppers it certanly sounds like the tuner control curcuit or the tuner itself is bad. With the back off the set and the tV on, if you tap on the side of the tuner does the set start to work? if so the tuner has to be replaced
Posted on Sep 25, 2006
Does this tv need a converter box or can I just use an antenna for over the air channels???
Most likely it needs a converter box. To see for sure, just turn it on and look at the channel type.
1. Channels are displayed as decimals, such as 17.1, 17.2, 17.3, 18.1, 18.2, etc. In this case it's a digital TV which needs only an antenna. Also usually TVs like this display no signal as a blue or black screen, though sometimes they can have the fuzzy gray screen.
2. Channels are displayed only as single numbers, 1, 2, 3, 4, etc. Most likely the screen is gray and fuzzy, maybe making a loud fizzy noise, when you have no signal. It's an analog TV and you need a converter box.
Apr 30, 2018 | Televison & Video
My RCA has a black block come up in the bottom of the screen? We have Dish Network Satellite and have programed the remote from the remote code guide. TV volume and channel changer work, but picture is a...
This has hopefully been resolved for you, but if not, here are some steps to go through. The black box that comes on the screen is usually signaling that closed Captioning is activated on the tv. Closed captioning does not run through the DISH Network receivers, so you can turn that feature off in your tv settings. The fuzzy picture could be a few things. You will want to check that all of your cables on the back of the receiver box and tv are tight as possible, and also make sure that the tv is on the correct channel. If you are in the room with the receiver, the tv will need to be on channel 3 or 4, and sometimes an input; usually video 1 or 2. If you are in a number two room, where there is no receiver, than you want to make sure that the tv is on channel 60 or 73. I hope that this helps!!!!!
Becki Barned
DISH Network Customer Service
Sep 11, 2010 | RCA F36650 36" TV
How do I get the picture?
The TV is usually set to Channel 3 or Channel 4. You may have a switch on the back of the VHS recorder near which is marked Ch3 Ch4.
Once you correct this, try the following procedure.
Some VHS have a tracking button that allows the user to tune to the best signal. The tracking can also be done from the remote controller.
Usually that tracking function is used as follows.
While movie is playing on the VHS unit and signal gets fuzzy, press the channel key repeatedly (for example >> to increase the channel number). f after awhile pressing the same channel change button does not find a better picture, you should press the other channel change button (to decrease the channel number <<) to see if the picture improves.
If that does not work, IT DOES NOT MEAN that you tv/vcr combo unit is defective. It could just be the movie. The tape is magnetic and it might have been accidentally demagnetized.
If picture is better with another movie/tape, your unit is definitely OK.
May 20, 2010 | Memorex MVT2135 13 in. TV/VCR Combo
I have an RCA 27in. screen TV. Cannot program, all is fuzzy.
try unplugging and plugging back in 2 minutes later. go to menu and find channel selection. scroll down to where it says channel. then using volume up and down buttons. will add or erase channel. just play with it and you will see what im talking about. go to channel 4 and press volume up. this will save channel 4 in memory. if no work, try turn on video souce and do a auto program in menu. fixed. enjoy!
Nov 09, 2009 | RCA F27252GY 27" TV
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
Snowy screen just pops up
Bad tuner in tv....might be possible to solder bad connect in
tuner...........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Tv only has select channels
If you have a good cable signal connected to the TV and it receives channel 50 nice and clear but all lower channels have nothing but snow, then the tuner is defective and needs to be replaced. This is quite an easy thing to correct. Sometimes resoldering all connections inside the tuner will bring it back to life, but in either case the set should be serviced by a qualified tech.
Aug 23, 2007 | Toshiba 36AF43 36" TV
Snowy picture on certain channels and only sometimes
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Sharp 32R-S50 32" TV Logo
69 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
