Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge xl44 Igniter clicks when not being activated by knob on front of stove
    Habit-Forming:
  • 171 Answers
There is switch behind the knob it most be wet or it needs to be replace they are call,top burner valve switches. white in color plastic.
Posted on Dec 11, 2008
GE XL44 gas oven
well..that's a gas issue, not an ignitor issue..did you check for the pilot to be active? or is this pilot less?
Apr 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
I believe my oven igniter is bad in my GE Profile XL44 Stove. How do I go about replacing it myself?
On most GE models: Remove oven bottom by removing two screws at very back of oven floor, lifting up back side of floor, pulling back a bit to disengage front of oven floor, and remove. Next, remove flame spreader, allowing you to see burner and igniter. It is easiest to remove the burner assembly to change out the igniter.
Mar 13, 2011 | GE Kitchen Ranges
Ge Spectra Xl44-three of 4 gas burners will not ignite without a match.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 19, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 oven won't turn off. Knob off and pin is loose
My GE XL44 oven would not shut off and it turned out to be a worn out thermostat for the oven. I have written up a step-by-step tutorial on how to replace the thermostat on my blog: John Fixes Stuff GE XL44 Oven Will Not Turn Off How To Replace Oven...
Jan 17, 2010 | GE Kitchen Ranges
Burner Igniter will not Spark
No, actually each knob has its own switch and any knob will energize the spark module which sparks at all burners. So, just replace the defective switch which slides over the shaft of the gas valve. Careful! unplug the unit, these are 120 volt switches. Good luck.
Jan 12, 2010 | GE Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
185 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
