Have a casio AP-60R power light comes on but appears no power to rest of keyboard anywhere all fuses seem ok is it the battery daughter needs it for uni help please
memmory24k
  • 5 Answers
SOURCE: Need power adapter for Casio Keyboard
Use The UNIVERSAL SERIAL BUS. or USB port
Posted on Jan 15, 2008
SOURCE: Re power to radio/navigation and dvd
replace fuse #9 i just did it and worked fine! the fuse is located on the passenger side, underneath the globe compartment
Posted on Dec 28, 2008
  • 1138 Answers
SOURCE: Casio CTK 2000- won't work with adapter
If you have a volt/ohm meter try checking to plug that goes into the keyboard for voltage on the DC setting. If there is none, you will have to replace the adapter. Be sure to plug the adapter into the wall when you check it or you will get no reading. If that is not the problem, then it is probably the receptacle for the DC end of the power supply. What happens is that if they get bumped the solder connector on the circuit board breaks. If you do not feel comfortable fixing this yourself, you will have to find someone who is capable. Hope this helps.
Posted on Apr 23, 2009
SOURCE: Keys on Casio keyboard pulled up
I have a Casio CT-648, which looks like a smaller version of yours. I had the same problem, and got brave and opened it up. I took off the back, which takes several screws. Once it was opened up, I saw the keyboard was fastened to the frame in sections of keys. I unscrewed the section with the raised key (I believe it was 5 screws), slid the key section toward the front of the keyboard, and was able to get the slides to re-engage with the tab below it. I now have a smooth keyboard.
Posted on May 11, 2009
  • 5603 Answers
SOURCE: Casio keyboard lit up, no sound, no responses
Unplug for several minutes and try again.
If that doesn't work, look up the "factory reset" procedure for your particular model via google and follow that procedure. It usually involves holding certain buttons down before and during power up.
Posted on Jul 25, 2010
Does my Casio g-200 keyboard have a fuse ? If so what type and where is it ?
I'd go exchange the power supply for the correct one (check the voltage, polarity and mA rating that's marked next to the power input). It may be too late, though.
There will be a fuse on the internal power input board, as well as one in the power supply, but if the instrument is turning on and lighting up, it's not a blown fuse.
Jun 29, 2016 | Casio Wk-200 Wk200 76-key Digital Personal...
My mom gave my daughter Casio ctk551 keyboard adapter has power and we've tried batteries keyboard will not come on noticed a little rust on back plate took off clean with dry cloth nothing any sugges
Rust is an indication that the unit has water or moisture damage. The keyboard should power up using batteries or the adapter. Is the adapter is one supplied by Casio? Perhaps the batteries were/are put in the unit in the wrong direction or polarity? Take the batteries out completely and then try the power adapter. If this fails, I suggest returning the Casio for a replacement.
Dec 27, 2014 | Casio Music
Casio fx-570W can use exponential notation
The key is marked "x-superscript-y" and is located near the upper-right corner of the keyboard
Apr 22, 2013 | Casio Office Equipment & Supplies
Casio CTK-651 keyboard wont switch on
An internal fuse is UNLIKELY.
More likely is either a bad connection/connector at power input or a bad or intermittent power switch.
Jun 24, 2010 | Casio Music
Power adapter specification ct-630
Hi - look in back or under keyboard for power specs.Then go to Guitar Center and the right adapter. GuitarCenter.com has casio power adapters.
Jan 04, 2010 | Music
My casio keyboards ac adapter does not power up the keyboard. I bought a new adapter and its still dead. I put batteries in it and it works. What could be the problem that the adapter would not work?
Try this out- check for a blown fuse. If you have never done this before, here is a simpler step by step procedure-
1. If you have the tools and little bit of adventurous spirit, I would suggest you open the keyboard and check for a fuse (a small glass tube with a metal wire running through it).
2. Pull it out and look at it against a light source (like a window) check if the wire if cut (that means the fuse is blown).
3. If it is not blown, put it back, if is blown find a shop that sells it- an electronic spare part shop that stocks stuff for TV, and computer spare will have it). Get a new one and put it in.
4. Try plugging the adapter again.
Best of luck...
Jun 08, 2009 | Casio WK110 Portable Keyboard
Apr 05, 2009 | Casio Portable Keyboard Touch Sensitive...
No power anywhere
bro, u need to check every single fuse(inside the car) and dnt forget the fuses under the hood check them too.
Feb 10, 2009 | 1990 Acura Integra Hatchback
Nothing shows on viewing screen
I had something like this occur with a minot mini video camera only it locked up in the "On" setting, meaning I could see a display on the screen but could not turn it off. I suggest you look very closely for a reset hole at the bottom somewhere, a place where a safety pin or the straightened end of a paper clip could be inserted. If no Reset can be found, then try holding in the Power On/Off for as long as 90 seconds. This may clear the problem. I would also suspect no power due to low charge or no charge on the battery, battery installed incorrectly, or battery not charged up.
Dec 10, 2008 | Casio Exilim EX-S600 Digital Camera
Casio LK-30 Key Board Piano
I have the same problem. I was thinking one solution for us, but I don't like it might be to solder the power supply on and skip that female plug entirely. To do that, you cut the male end off the transformer/power supply wire (if you don't want to ruin your transformer/power supply you can buy another power supply at Best Buy for $10 - Dynex DX-C1109). Then strip the ends from each wire from the power supply so you have some bare wire showing on each wire. One goes on the spiral thing sticking up from the JCM470 board, the other goes anywhere you want on the red wire coming from the battery compartment. You should test before you solder to make sure you the proper one on the proper wire and that you therefore have power to the unit and it makes a sound. But its a sloppy fix. While it should work perfectly, the power pack then can't be changed unless you solder and unsolder it each time. Another solution is to find a broken LK-30 or LK-33 and rob the circuit board if it still works on the parts machine. Trouble is if you find one and its not near you it costs some money to ship these. At some point its just easier to buy a used one on Ebay or craigslist.com, I guess.
Nov 29, 2007 | Compaq Evo Notebook Keyboard N610C/N600c
170 people viewed this question
 Grubhead
Grubhead
