Question about Amana AGDS902 Gas Kitchen Range
Amana First Edition stove
Hi I have an Amana First Edition stove an the oven is not working right when i turn my oven I can see the glow plug light up and some time the oven will and heat up and other times it won't the glow plug has replaced and lights up but the oven won't when I turn it to broil it works everytime?
5 Suggested Answers
SOURCE: Amana ARG7300w oven inop
It has a bad oven igniter.
Posted on Aug 27, 2007
SOURCE: Kenmore Electric Stove - Gourmet Edition
Hello! I have this stove in black where something went bad inside last week (made like a crunching sound). It still runs but seems to only be getting 110 electricity. Clock and lights work and the large oven stays warm. Everything was working fine until this happened. Could be an inexpensive fix- I willing to sell it for repair or parts if you are interested. The griddle alone sells for $170.00 through Sears. Cynthia
Posted on Jan 01, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: the oven is not getting hot
Check the valve in the back under the broiler. You can put a volt meter on it and see what you are getting. If it is not opening properly that could be bad. The other thing could be that the valve on the knob is bad and then that needs to be replaced both can be checked with a volt meter.
If you are happy with my hlp please rate. Thank you
Posted on Feb 11, 2009
Maytag317
  • 1136 Answers
SOURCE: whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on May 27, 2009
I have an amana gas stove, the burners work and so does the broiler, but the oven does not light. The pilot light goes on but I'm not getting any gas.
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Amana Kitchen Ranges
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven wont work after disconnecting the power
clock going out. need to check to see if your igniter is glowing. it could be glowing but still be to weak to open valve
Jun 22, 2009 | Maytag MGR5751AD Gas Kitchen Range
Pilot Light Wont Light
Take off the top cover plate inside the oven. Now with the door open turn the oven on does the hot surface glow? If it doesn't glow then you have a bad igniter and needs to be replaced. What ever you do don't touch the surface of the new igniter human oil will shorten the life of the igniter. now if the hot surface glows then the gas valve is bad and need to be replaced. I'm betting it's the hot surface.
Nov 25, 2008 | Amana Ovens
Amana First Edition, oven is not working but broiler is
my amana oven when i turn it on it glow but take a long time to light about five mins
Jun 27, 2008 | Kitchen Ranges
Amana AGDS902 Gas Kitchen Range Logo
1,390 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
