Question about GE GSS25JEMWW Side by Side
Howling noise in the evaporator fan motor
I have GESS25QGPD refrigerator. The motor in the evaporater seems to have a howling noise and the motor seems to slow down as it has this howling sound.
  • Anonymous Feb 21, 2009
    GE GSH22KGRE has fan that howls. Any Ideas?
    Jay
    Problem Solver:
  • 18 Answers
Bad computer board in back of fridge, unable to control motor speed causing motor to hunt
Posted on Nov 15, 2008
GE model GSS22JERF BB keep hearing loud howling noise coming from the freezer size. Don't know the cause
Uh-huh... Ivy Joseph,
Well ...
unless your cat is missing that characterization is going to need some EXPANSION... clarification... definition.
The door is open/closed has no impact on "howling"...??
The unit is OTHERWISE WORKING... (????)
or some issues have accumulated to attract your attention.
Your diagram shows a pretty standard side x side configuration...
a "WORKING" refrigerator won't be howling. An iced up refrigerator can encase the EVAPORATOR FAN... and the howling will be that fan shaft spinning in a FROZEN FAN.
The noise should stop on OPENING the door...
Iced up... can come from several sources
- huge air intrusion
- Defrost circuit failure
Go to the location below to get an idea of how our machine fits together...
The part depicted is the second LEAST LIKELY
failure point (defrost thermostat)... First least likely
is the defrost heater element...
Most likely... DEFROST TIMER (or PCB)
Hope this helps... comment me back with progress questions (I'm usually here daily)
appliance parts
Search Over 2 1 Million Appliance Parts
defrost-limiter-thermostat (and video)
http://www.appliancepartspros.com/ge-defrost-limiter-thermostat-wr50x10068-ap3884317.html
Partsselect
PartSelect Appliance Parts and Repair Help
Jan 05, 2017 | GE Refrigerators
Howling noise
Check the help link mentioned below:---
Click the link:--
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
These will help.
Thanks.
Nov 21, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Howling noise from freezer fan, GE side-by-side
Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
Dec 17, 2009 | GE GSF25XGR Side by Side Refrigerator
Anyone solve the howling problem please share.
sounds like the fan bearings are wearing out. this causes imbalance and makes a vibrating howling noise.
Aug 26, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
My fridge is howling pretty loudly when ever it runs , the howling is coming from behind the ice maker turned the ic e maker off but unit st ill howls what s wrong
Hi, It sounds like the evaporator fan motor is going bad or there is frost building up and hitting the fan blade.
Unplug the refrigerator and remove the rear panel inside the freezer and locate the fan.
You can plug the refrigerator in and see if the fan is making the noise.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whining/howling on freezer side
Need to unplug the refrigerator and remove the cover inside freezer compartment. Sounds like the evaporator fan is hitting something and we need to resolve this as soon as possible. Thanks Sea Breeze
Mar 26, 2009 | GE Refrigerators
Howling noise in frig
You need a new Fan motor . Or oil in the right place may do if it not worn by now.
Feb 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
Noisey ge side by side
hi thanks for the question that noise is the fan in the freezer.you replace the fan motor the water disp problem is the little switch inside the freezer door difficult to get at please accept with a positive feed back thanks the appliance doc
Sep 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25JEMWW Side by Side Logo
381 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
