Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
PS3 to Sony KP-57WV600 HDMI/DVI Conversion Cable Problem
I am tryng to get the PS3 unit to play through the KP-500WV600's DVI input. I tried using HDMI cable to HDMI/DVI converter and straight HDMI/DVI conversion cable to no avail. I followed PS3 instructions on shutting downing the unit and starting up waiting to hear the two beeps. Nothing seems to work. The DVI input on the Sony KP-500 unit is working because I have connected other equipment to it.
The only way I can get the Sony PS3 to work is using the Component AV Cables. I would rather use the HDMI/DVI conversion cable - is there a fix or am I wasting my time.
Thanks
  • lawrencelum Dec 28, 2008
    I just bought a Sony Blue Ray BDP S350 and was wondering if I can purchase a HDMI/DVI adapater to convert the Blue Ray and not sacrifice on HDMI? I do not want to want to buy another newer TV at the moment.
  • miltonsway Apr 18, 2009
    I have the exact same problem. But mine is going from a ps3 to a Sony SDM-S95fr monitor. I gone through the same troubleshooting procedures and still no picture.
bluenadas
  • 203 Answers
SOURCE: JVC AV-48WP34
Have you got the cable connected properly and attempted a consumer convergence in the menu? If you've attempted that and are still having the issue there may be other components on the Conv Module that have failed.
Posted on Jun 08, 2007
Heiny
  • 10 Answers
SOURCE: PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Posted on Dec 17, 2007
J4XXN
  • 182 Answers
SOURCE: Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
Posted on Jan 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: conversion probleme with jvc av-48wp74 i
you need new convergence ICs STK392-110 ICs and the JVC convergence resistor Kit #1 you can get the parts at the following link with free instructions and free online tech support to help you with the final adjustments after install. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Aug 10, 2008
SOURCE: My screen is purple, and my ps3 games display with purple colors.
I had the same problem and i tried what you tried and no result. Came to find out it was my tv. Depending on your tv you have to programe it just like you had to program your ps3. And if that doesnt work its your monster cord. Ask some one at best buy to help their pretty good.
Posted on Dec 18, 2008
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
I own a KP-57WV600 Sony Projection - I would like to know where the HDMI connection is ?? on the back of the TV
Sorry there is no HDMI connection on back or front of TV.
You can not use HDMI cable on the TV.
Good Luck
Oct 05, 2009 | Sony Televison & Video
Play station 3 hdmi-dvi
Yes you can. It will not be like a HDMI cable but it will be better than the RCA. Your image will be in your HDTV (1920 × 1080). But you will have to buy a HDMI cable and and HDMI-DVI adaptor. You will not have sound so you will have to connect either your RCA or if you have a Digital Optical Audio sounds better.
If you have any questions just ask.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Ps3 video and audio comes and goes
TRY playing game using standard line input cable and see if there is a difference
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3 hook up
Yes, you can! But not straight out of the box. You need to purchase a DVI to HDMI cable adapter. It will convert it so your tv can use it. Here is a link to some:
http://www.connectworld.net/syscon/dvi-to-hdmi-adapters.html
Hope this helps! Please rate me!
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Ps3 hdmi to dvi on mitsubishi wd52327
What brand DVI connector and how many pins are on the connector. try a different cable
Dec 25, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
395 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
