Question about Bissell 6590 CleanView Bagless Upright Vacuum
Bissell 6590 wheel unit pins snapped, where can I get a replacement part
The wheel unit on my bissell 6590 had two plastic pins, one on each side that held it into the bottom of the machine. The numbers on the part are BODY H/A 3
DJ61-00197
ABS WS 4
Where can I find a replacement part, or is it time for a new vacume. The vacuum still works, I hate to spend the money on a new one if I can fix this one. Thanks, Darlene
This is a very easy repair. I got a hose clamp. 1/2" wide, solid edge. Take your time and bend it the inside shape of the holder. drill 2 matching holes, It's a perfect fit.
Posted on Dec 16, 2008
My bissell 6590 works fine with hose attachment. Motor shaft turns when belt and roller are off. When belt and roller are on it's noisy and smelly. Now one end of the roller actually melted in the holding...
replace the roller,belt and before instalation clean motor shaft where belt rolls. you can turn on the vacumm and using a knife scrape the motor shaft from the black dirt.
Feb 19, 2011 | Bissell 6590 CleanView Bagless Upright...
Bissell proheat turbo 2x upright cleaner -how do I reassmeble?
Yeah, it’s annoying that the manual doesn’t give more detailed instructions and drawings to help with this, because you do have to take the roller assembly apart sometimes to clean built-up carpet lint off the unit properly. If you don’t do this, I’d expect you’d have more problems.
I have a different model number Bissell Proheat than yours. Yours may have different parts or go together differently than mine, but I'll tell you how I do it on mine and you can try my way out and see if it helps you.
(In all cases where I use left vs. right or front vs. back, as when these terms are used with a car, I am facing the front of the Bissell. I am NOT behind the Bissell, where I would stand when cleaning carpet with it.)
Here's how I put it together. This takes much longer to describe than to do, once you figure out where everything goes and you get the hang of doing it!
Attach the left arm with the two silver rods (ONLY attach the left arm here-- leave the corresponding right arm, which looks like the left arm except it has no silver rods, off the bottom unit of the Bissell, for now) to the left side of the Bissell, with a silver screw with a built-in washer. The screw hole is on the back end of the arm and the arm dips down towards the front of the Bissell and holds the two brushes in position so that they can turn without striking the top of the underside of the Bissell or dragging on the floor.
Put a small silver washer on each long, silver metal post, where the roller brushes will go, and slide it all the way to the left.
Put the larger rubber belt around both metal posts, about halfway to two-thirds of the way down the metal posts.
Slide the brushes halfway down the metal posts and attach the larger rubber belt to the cog wheel on the left side of each roller brush. Then slide both roller brushes with the large rubber belt attached all the way to the left so that the cog wheels are against the inside of the left arm. As you move the roller brushes almost all the way to the left, you may be blocked from reaching the end until you carefully work the rubber belt around a plastic flange on the inside of the left arm, but do this and be sure the roller brushes are up against the inside of the left arm. Make sure the rubber belt is still on each of the cog wheels when the roller brushes are pushed all the way left. If you turn one roller brush, the other should turn, too, because of the belt attached to both cog wheels.
Put the small belt around the small cog wheel on the bottom unit of the Bissell behind the right end of the back roller brush, and also around the cog wheel on the right end of the back roller brush. (The right cog wheel on the front roller brush is the only one of five cog wheels without a belt, when everything is assembled correctly.)
Put a small silver washer on the right end of the silver rod passing through the back roller brush.
NOW attach the right arm, using a silver screw with a washer, to the middle screw hole on the right side of the bottom unit of the Bissell. The right arm should mirror the left arm, so that the two arms hold both roller brushes in position on the right side and straight across the bottom unit of the Bissell. It is normal for the roller brushes and arms to be able to flex up and down a bit, when everything is put together correctly. The built-in washers on the silver screws which attach the arms keep the arms and roller brushes in the generally correct position but allow them to flex.
Now using your fingers you should be able to slowly spin the roller brushes without the brushes contacting the top of the bottom unit of the Bissell and without dragging too low against the floor. Check one more time and be sure the belts are positioned correctly around four of the five cog wheels.
If everything seems right, attach the two side covers. These are not interchangeable; the left cover only fits on the left. The short black screw goes in the back screw hole, and the long black screw goes in front.
Then attach the front cover. It's important to be careful that the hooks on the front cover are inside the side cover holes designed to hold the hooks before trying to tighten the last screw through the tab on top of the front cover. If you aren't careful about this, it's easy for the front cover to be out of position or to break its tab.
Try powering up the Bissell and see if the rollers spin correctly. Remember that the handle must not be locked upright and the trigger must be depressed with the Bissell turned on before the roller brushes will spin. (Sometimes people complain that nothing happens with the unit turned on and the trigger depressed when the only problem is that the handle is in the locked upright position.)
May 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Replacing the little black rubber belt
bissell.com has videos on how to replace belts.
May 04, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Cleaning the bissell little green
Bissell 1425 works great, but today will not ****! Spray is fine....just no suction, even without any attatchments.
Oct 11, 2008 | Bissell 1425 Little Green ProHeat Handheld...
Bissell 6590
It is called the detent lever part # 2030052. If you can't order it from bissell.com or over the phone, most repair shops should be able to order it for you.
May 21, 2008 | Bissell 6590 CleanView Bagless Upright...
Bissell 6590 handle height adjustment
The handle adjustment knob part # is 2031095, the height adjustment wheel asm. part # is 2031330. You might try bissell.com and see if you can order direct from them. If not, most repair shops should be able to order for you.
May 20, 2008 | Bissell 6590 CleanView Bagless Upright...
Replacement wheel
The rear number is 2036627, there is no side casing, you would have to replace the whole back, which Bissell isn't making avaiable. But o get the wheel, you might try bissell.com and see if you can order direct, or try a local repair shop to see if they will order it for you.
May 06, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Too loud noise of Bissell 6590-W vacuum cleaner
When they get real loud either the motor bearings or the motor fan are bad and you will have to replace the motor, part #2031100, would sell for about $45.
Oct 04, 2007 | Bissell 6590 CleanView Bagless Upright...
Bissell 6590 CleanView Bagless Upright Vacuum Logo
418 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
