Question about Game Elements HV-5 (GGE904) Wheel And Pedals Set
My HV-5 not working with Cabelas Off Road Adventure 3. I go into windows XP control panel and do a the calibration stuff and everything looks good with the HV-5 wheel but in Cabelas Off Road Adventure 3 control options screen the HV-5 is not there. I ask adive from Activision games and they suggested update the driver, so i did that and also i got the newest DirectX from microsoft. any ideas on getting my wheel to work, its a good looking peice of equipment and i would really love to use it on this game. thank you
  • PLAYA PLAYA Mar 06, 2008
    my steering wheel (it's an APOLLO) is not detected by cabela's off road adventure 3!!!
    what can i do? i bought the wheel especially for this game and is not detected!!! Does anybody know how and what to change in the game to make it work? I think is not the wheel who needs an updated driver but the game needs a patch/fix to recognize all steering wheels!!!
    TAHNX IN ADVANCE , I AM WAITING FOR A SOLUTION ,
    LIVIU
GO to OPTIONS>CONTROL SETTINGS AND DEFINE THE KEYS BUT INSTEAD INTRODUCING THE CONTROLS FROM KEYBOARD, MAP THE FROM THE WHEEL. To be more specific: for steer left if you have the key left assigned <- , redefine it and instead move the wheel to the left. Do this for every command of the vehicle which was previously assigned to a key and replace it with a control/command from the wheel.
Have Phun!!! ;)
Posted on Feb 07, 2009
How do i get the pen an tablet to calibrate
Assuming you are running Windows XP Tablet Edition:
Go to Control Panel Select Tablet and Pen Settings Tap the Calibrate Button
Follow the instructions.
There should be a similar Tablet control in the Control Panel for other versions of Windows.
Apr 19, 2011 | Gateway M275 Tablet PC
I've upgraded my computer n hv windows 7 n my scanner Umax Astra 5600 does not operate on the new computer. I need yr help in getting the driver for windows 7 for my Umax Astra 5600.
most old scanner are not working with windows 7 and also 64bit of win 7
VueScan is bringing them to life ;)
http://www.hamrick.com/
Feb 28, 2011 | Computers & Internet
I have a 1997 plymouth grand voyager. Everything was working fine until my battery died. Replaced battery & now my rear window wiper lights on the dash blink constantly. The wipers work fine when I cut...
What has most likely happened is that the Heater-a/c unit needs to be recalibrated and here are the steps to do so.
With the engine running and fully warmed up, A/C has to be turned off for at least 5 minutes [don't turn it on at all] and transmission in Park do the following
1. Set the temp control all the way to cold
2. Set the mode selector to Vent so air blows out of the dash panel outlets.
3. Hold down the rear washer button and the rear wiper buttons simultaineously for about 5 seconds until most all of the heater and ac panel lights blink and then release both buttons
6. At this point the system should go into a self calibration test which can take up to 60 seconds. While it is calibrating various control panel switch lights will blink as it goes through it's tests.
7. When the system is done calibrating then just the rear wiper light should be flashing and you can exit the test by turning off the vehicle. Wait about 10 seconds and restart the engine and it should be fine. If both the rear wiper and intermittent light are both still flashing after the calibration then there is most likely a problem with the system that will need more diagnosing. I see this fairly often with battery replacements so I think you'll be ok. It sometimes takes a couple of tries to calibrate so don't give up if it doesn't work the first time. Good luck, hope this helps!
Jul 14, 2010 | 1997 Plymouth Grand Voyager
Do I need a driver for wingman attack 2 on Windows XP, I can't get it to work. I'm very very new at this.
The drivers from Logitech help and can be downloaded from thier support site. The software they have lets you use profiles for all the games you play with the joystick, that way you don't have to constantly calibrate it for each game. The windows drivers will work the joystick....just have to go to control panel, game controllers and enable and calibrate the joystick.
Aug 31, 2009 | Logitech WingMan Attack 2 Joystick
Blinking airconditioning lights
TO INITIATE TESTS:
1. Set blower to HIGH
2. Set mode position to PANEL (AC vent air)
3. Open all AC outlets
4. Temp. on full cold
5. Start engine
6. Push WASH and REAR WIPER switches for 5 seconds until all panel lights are on solid
System will then go through it's paces as it calibrates the climate controls
7. When calibration is complete only the REAR WIPER switch/light should be flashing. Press this switch to extinguish the light
This will stops blinking lights.....
Good Luck!!
Thanks
Aug 08, 2009 | Plymouth Voyager Cars & Trucks
Cabelas Big Game Hunter Alaskan Adventure ''Out of Range''
well for ONE YOU HAVE TO GIVE IT ALITTLE TIME, THIS ISN'T LIGHTYEAR SPEAD STUFF YOU HAVE SO BE PATIANT. KNOW A COUPLE OF THINGS TO GO THROUGH WHILE SCREEN IS BLANK. PRESS CTRL + ALT + DEL THIS WILL NOT EFFECT YOUR GAME, ITS GOING TO ALLOW YOU TO OPEN YOUR TASK MANAGER. ONCE YOU HAVE IT OPEN IN THE BLACK SCREEN MAKE SURE IT IS RUNNING. DO NOT END TASK THIS IS IMPOTANT DO NOT END TASK. OK KNOW IF YOU COULD NOT PULL UP YOUR GRAFIX CARD IS GOOD BUT YOU MIGHT NEED TO UPDATE IT. ALSO YOU ARE RUNNING ON A COMPUTER THAT MY BE USING ALL THE MEMORY TO RUN THE GAME THIS IS CALL FREEZE STALL. GOTO A FRIENDS HOUSE INSTALL AND PLAY IT.
REMEMBER GAMES LIKE THESE OBLIVION, CABELAS, THEY NEVER PROGAMED THE GAME TO USE A LITTLE SPACE. YOUR COMPUTER WILL RUN HOT DUE TO THIS SO MAKE SURE ITS RUNNING COOL. THAN IF YOUR STILL NOT CONVINCED, LOOK AT THE BACK OF THE CD AND LOOK FOR WAVY RAINBOWS. SOME CD'S ARE HEATED UP BEFORE YOU BUY THEM AND REDERS THE DISC USELESS.GOTO THE TECH SUPPORT SITE FOR THE GAME AND THEY MAY TELL YOU TO HAVE IT REPLACED.
Aug 06, 2009 | FROM Software Cabela''s Alaskan Adventures...
Logitech attack 3- Z axis- throttle "default" starint value
have you calibrated it?...."start" "control panel" IN **CLASSIC VIEW** click the GAME CONTROLLERS and then propertys...it should say your device and after highlighting you stick a window will pop up hit the SETTINGS tap and hit CALIBRATE do what it tells you and try using it again....
May 16, 2009 | Logitech Attack 3 Joystick
Hp Dv6000, problems recording with built in microphones
For Vista:
1) go to Start > Control Panel > Sound
2) click the recording tab
3) Right click the device that is not the new one you bought.
4) choose Disable
For XP:
1) Right click My Computer or go to Start > Control Panel > System
2) On the system window click the hardware tab
3) Click the Device Manager button
4) Scroll down to the Sound, video and game controllers.
5) Look for any device that is not your new mic as well as your sound card.
6) Right click and disable anything that are not the mentioned above.
7) Exit and test.
If you have XP and the XP Method above doesnt work then please make a comment stating so so I can give you another solution.
Dec 17, 2008 | HP Pavilion dv9000z Notebook
Pen Problem
First try updating to SP2 and then get the latest Windows Updates from Microsoft.com.
If that doesn't fix it, here are some Win2000 drivers for your laptop.
http://www.fujitsupc.com/www/content/exe/PenW2k1.4.exe
http://www.fujitsupc.com/downloads/mobile/st3400_pen_w2k.exe
If that doesn't fix it, try these Wacom drivers.
ftp://198.145.255.42/drivers/IBMPC/consumer/503/PenTablet_503-3.exe
Oct 17, 2007 | Fujitsu Stylistic LT C-500 Tablet PC
Game Elements HV-5 (GGE904) Wheel And Pedals Set Logo
441 people viewed this question
Top Game Elements Video Game Consoles & Games Experts
Marvin
Marvin
MegaByteMe
MegaByteMe
Are you a Game Elements Video Game Console and Game Expert? Answer questions, earn points and help others
