Question about HP PSC 2110 Color Printer
Psc 2110 carriage jam
Error message states carriage jam open door clear jam
upon opening door carriage does not center itself to look at cartriges. one has to move it to center to remove cart upon closing door the printer makes a gear strip sound trying to move the carttrige.
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Aug 21, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 2210 has the error message 'Open Door, Clear Carriage Jam, and then Press Enter'. No paper jams present?
Check door for paper stuck in front of sensor. There is a door in the back look to see if paper shred is in there infront of the back door sensor.
Jul 27, 2010 | HP PSC 2210 All-In-One InkJet Printer
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Error message "clear carriage jam"
Did you take out the caritride and check whether there is a paper or any part of a paper in the printer ?
If it is ok
Reinstall the printer driver
Jul 21, 2008 | HP PSC 2110 Color Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Printer is not working
Hold set-up button and , still while holding set-up button, press the option button, should be ready to go now!
Nov 07, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2110 Color Printer Logo
292 people viewed this question
Ben Johnson
