Question about Yamaha RX-V463 Receiver
Yamaha RX-V463 component hook ups
I have an RX-V463 and can connect with composite and HDMI but when I connect using component (VCR and WII), I only get audio (no video). I can connect these conponents to my sony LCD directly
with no problem and the manual is no help (been through all of the on screen menus as well)
Any help?
I canot get my center speaker to work
Posted on Dec 03, 2008
This receiver does not have video conversion capabilities. In the owners manual it mentions this. So HD in = HD out. Analog in = analog out on the video portion
Posted on Nov 06, 2008
I am using a logitech harmony one remote. i have a yamaha rx-v463 hooked up to a phillips hdtv, i am running hdmi from revr to tv. i have cable box hooked upi hdmi to recvr and bluray player hooked up to...
The remote has nothing to do with this.
Get into the manual. Page 14 says Component Video In will go to Component Video Out, not HDMI. No analog-digital video conversion is implied.
Jul 08, 2011 | Yamaha RX-V463 Receiver
Yamaha Receiver RX-V367. Connected a WII to the audio/video jacks in front. Sound but no audio Do I need to select a certain device from input menu?
I am trying to connect my Wii with the component cables to my yamaha rx-v367. No video but sound. What am I doing wrong?
Jun 19, 2010 | Audio Players & Recorders
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
Connect my xbox on reicever
If your xbox has HDMI connector then you HDMI cable to connect it to the receiver and another HDMI cable to connect receiver to the TV. Receiver should support both video and audio over HDMI.
If your xbox doesn't have HDMI, connect the video directly to your TV using whatever connector/cable is available (in terms of quality from best to worst: HDMI, component, s-video/scart, composite).
Then connect audio to the receiver via optical spdif cable.
Jan 29, 2010 | Yamaha RX-V463 Receiver
I have wall mount tv connected to surround sound receiver with hdmi ,im trying to hook up wii to receiver instead of running them up wall to tv how do i do it
Connect the wii cables to the TV/SAT IN on the receiver. Then connect a video cable of your choice from the receiver "MONITOR OUT" to the input of your choice on the TV.
Dec 31, 2009 | Yamaha RX-V463 Receiver
Best way to hook up TV with one HDMI to blue ray DVD and RX-V465 receiver with Direct tv
Has Direct tv STB HDMI output?
Best is to connect all your sources (BD, DVD, STB, PS3) to yamaha receiver and connect yamaha hdmi-out to TV's HDMI-in.
Dec 29, 2009 | Yamaha RX-V463 Receiver
I need to hook up a yamaha 465 receiver
It has two HDMI inputs and one HDMI monitor output for the TV, so assuming all your devices are HDMI-capable, YES.
http://www.crutchfield.com/p_022RXV463/Yamaha-RX-V463.html?tp=179&tab=features_and_specs
Nov 28, 2009 | Yamaha RX-V463 Receiver
The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Apr 07, 2009 | Yamaha RX-V463 Receiver
I have the Rx-V661 and I just got the WII. I input the WII into the Video AUX on the front panel and pressed the aux button on the remote and nothign happened.
Just a thought, but, how do you have your TV/Monitor hooked up to the Yamaha unit? If your only connection between the receiver the and the TV/Monitor is an HDMI cable, and you are plugging your WII into the front v-aux jack using composite video, the receiver will have no way to send the video signal to the TV/Monitor. The receiver upconverts all composite video and S-video signals to component video signals. This means that if you only have an HDMI connection between the receiver and the TV/Monitor, you will also need to establish a second, component video connection between the receiver and TV/Monitor to handle the upconverted WII video signal. You will probably also need to switch your TV/Monitor to use that input when you are using the WII.
Of course, if you already knew this and have it set up that way, this answer won't help you at all!
Dec 25, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V463 Receiver Logo
527 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
