Optical disc drive
The optical disc drive on my Sony V10 will not read installation discs. Will read CD's and DVD's
  • 849 Answers
Must be installtion CD problem, clean the CD drive lens
Posted on Nov 03, 2008
It will not play Verbatim DVD-R disc that I burnt on my computer.
If it can read any other disk, you should burn your disk again because burning process was incorrect. your computer can't recognize the disk. In this case, probably you can't do anything, no way to try to read a bad disk if computer can't even "see" it.
By the way, you should test to read the disk on some other computer.
If happens with ALL your disks, your optical player is defective.
Again test reading with other computer if record was made correctly
As for your device, you should check if worth to repair and decide if repair or replace it.
How to Replace DVD CD Drive in Computer Tower
How To Install Computer CD DVD or Bluray ROM Drive Ep 7
Replace Laptop DVD CD Optical Drive Complete Tutorial
How To Replace the Optical Drive HP Pavilion DV6 Laptop HD
Sep 03, 2015 | Televison & Video
My cd/dvd player is not working or read dvd disc... what would i do to read such dvd disc in my player..
Good day,try to insert original cd/dvd disc,but if it's still not working.may be your player is defective.i advice you to use external optical disc drive.God bless!
Aug 18, 2011 | Acer Computers & Internet
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Jan 30, 2011 | Lite On XJ-HD166S Internal DVD Drive
My dvd/cd does not read data disc. It's running on vista Ultimate with Chrome.
Optical drives tend to wear out. Try the disc on another PC. If it works, then your drive is dieing
Apr 07, 2010 | IBM ThinkPad T60 Notebook
When i insert a cd or dvd into mu MAC powerbook
Check to see if your discs are dirty. Clean them and try again. Also, check to see if you got heavy scratches on the discs. Also, click on the blue apple logo at the top of the screen, then click on about this mac,then click on more info. Under the hardware click on the disc burning title. Look at CD write and DVD write info to see what the burner will play. If no info is there, then your optical drive is disconnected from the logic board or your optical drive is toast. If your optical drive spits out every single disc, then that also means it needs to be replaced.
Nov 05, 2009 | FastMac (APP-5693) for PowerBook G4...
Dvd will not burn to disc
replace the drive with a standby n see..
..contact ur System Admin/Vendor
Oct 27, 2009 | Compaq Presario 5000 PC Desktop
Cd Drive in Mac iBook 4 is malfunctioning. Disc will not mount.
Shut the machine down. Find the original CD or a retail OS X installation DVD. Start the machine up and immediately hold down the option key. You will see a icon of your hard drive. Now insert the CD or DVD. If it immediately spits out, your optical drive needs replacement. If it does not, click on the U-shaped arrow button to rescan the drives. If the CD/DVD does not show up, your optical drive needs replacement. If it does, choose it and boot from it. If this actually works, you may have a software problem -- this is low probability, but possible.
Keep in mind that the CD and DVD read heads are separate. If one of those is malfunctioning, your drive will accept CDs but not DVDs, or vice versa. If you see this behavior, your optical drive needs replacement.
Oct 06, 2009 | Apple Computers & Internet
Epson Stylus SX100 installation CD is not read
There are chances that the installation CD is faulty itself. If it is the original manufacturers installation CD, and appears to be free of scratches and smudges, this is most likely not the case. I would insert a combination of at least one other software CD and one recordable CD in the CD drive of your computer CD/DVD drive to see if these discs are being scanned, read, and show data on those CDs. We want to pinpoint the problem, to make sure that the hardware failure of CD Drive is not to blame, but it could be.
A Disc can spin around in an optical drive, and have laser read issues, and still end up being faulty, and eventually need to be replaced.
If you determine that you need a new Printer installation CD/DVD, and all other data discs work fine in that optical drive, you can download printer driver software directly from the manufacturers web site.
If you provide me all the model and manufacturer details of your new printer, I can locate this direct download link for you, and provide that to you.
Best of Luck!
Xpertdragon.
Mar 22, 2009 | Epson Office Equipment & Supplies
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Computers & Internet Logo
David Payne
David Payne
