Question about Soyo DYLT032D 32 in. LCD Television
Soyo model mtprtp3208nb
When i power on the tv the power light comes on but i get no picture i press on menu and source button and still no picture. any help would be appreciated.
Thanks
  • FixerMan4U Nov 15, 2008
    I have the same problem ..have had the TV for about 3 years. Power light flickers and no picture.
    I suspect its the Power Board. The Power Boards Model # is FSP 230-5M01 and the Part # is 3BS0105613GP Went to the FSP site and entered the Model # and the Part # and didn't find it.
    Anyone know of another source for this board beside the usual answer E-Bay?
  • john Nov 21, 2008
    If it is your power supply. you should check for bad capacitors. by checking for bulging on the top. if you find some bad caps. just replace with ones of the same values.
Replace all bad capacitors(end raised up) on power suply's main board. That'll fix it. fixed mine :)
Posted on Dec 21, 2009
  • john Oct 06, 2010
    That is what i did and and my tv now works. none of the caps were bulged but i replaced them anyway.
  • Mike May 12, 2011
    May i ask how you replaced them? how must i do it? any suggestions or help would be great thanks.
Samsung led tv no picture
What did you do when you say you cleaned the screen? If you shine a flashlight on the screen can you see some very dim picture? If the back light is out. This will require replacing the power board.
Jan 06, 2014 | Televison & Video
How do you set up the Soya TV. Is it cable ready?
Yes, your TV is cable ready. To set up, you will need to use the original remote and complete the following steps.
1. Connect your cable box to your TV using either antenna (RF) cable or component A/V
2. Press the "MENU" button on your remote
3. Select "CHANNELS" using the up/down arrow buttons on your remote and press "OK"
4. Select "SCAN CHANNEL" and press"OK".
5. Select "CABLE" as the source and press "OK" to tune
The TV should now automatically tune the cable stations and exit the menu. If you need to exit the menu and/or start again just press "MENU" on the remote again.
If you have no picture, press the "INPUT" button on your remote repeatedly until the input is on "TUNER" if you are using an RF cable or "COMPONENT" if you are using component A/V cable.
Your TV should now be setup for watching cable.
Please post back if you need further assistance.
Regards,
BElectric
Dec 05, 2010 | Soyo MT-SYTPT3218AB 32 in. LCD Television
Tv picture wont turn on
Press the menu button if the menu does not come up then the issue is with the tv. If the menu does come up , try a second source such as a dvd player or a game system. you may need to change the channel on the tv or the input to get video and sound.
May 06, 2010 | Panasonic PT-56DLX25 56" HDTV
TV will not turn on until I unplug, then plug it back in.
I have the same problem with my Soyo 32" lcd tv. Seems a lot of people do. Soyo went out of business, but I am going to see if it is the capacitors, like several people said on here.
Dec 21, 2009 | Soyo DYLTO32A 32 in. HD-Ready LCD...
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
Soyo DYLT032D - grey box in corner, no main picture or sound
I am having the same problem. Does anyone know the solution?
Oct 29, 2009 | Soyo DYLT032D 32 in. LCD Television
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
My Soyo DYLT032 has power but no picture or sound
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Dec 28, 2008 | Soyo DYLT032C 32 in. LCD Television
Problems with Soyo DYLT032C 32 in. LCD Television. The TV will not turn on, I have un-plugged it and plugged it back in, in hopes it would re-set the tv. Do you have any suggestions?
Long story short:
Dec 10, 2008 | Soyo DYLT032C 32 in. LCD Television
Mits. 1998 vs50603 48in.
Good Day, WADE N;
Some Models will shut down when no signal is detected.
Try unplugging the TV from wall/power source for 3 to 5 minutes.... plug back. Same thing? Go into OPTION MENU, press 'MENU' button on the remote > enter 1270. Choose reset system. If not there go to the SERVICE MENU, press "MENU > 1257 (same thing).
CAUTION: before you change any settings, document them (write down).
Good Luck, big IRISH.
Aug 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Soyo DYLT032D 32 in. LCD Television Logo
513 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
