Question about Onkyo DV-SP501 DVD Player
My dvd player just gives the welcome note and hangs up, and if i turn it off it displays the good bye message and switches off....but nothing in between.....no button is working either on the machine or the remote....the disc tray doesn't come out too......pls help the model is onkyo dv-sp501
    Top Expert:
  • Onkyo Master
  • 54,592 Answers
Go buy a replacement player , they are throw away items
Posted on Feb 06, 2018
4 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: Onkyo DV-SP405 DVD player says no disc
This woud be due to two things
1. laser
2. servo motor not spinning to the correct speeds i,e Bad motor
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 11, 2009
SOURCE: My onkyo DV BD-507 only
My onkyo DV BD-507 only play dvd disc, and dosent play blu-ray disc
Posted on Dec 04, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have a Onkyo DV-SP
Hi hannesswart,
Yes, Region 2 is for Japan, Europe, South Africa, and Middle East. Since you're unit is in correct region and same with the disc you are trying to play and still it came up with the "no disc" error, it means that the fault is in the optical lens assembly.
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jun 29, 2011
How do I get rid of all these zeros moving accross the display
This problem maybe is caused by a software bug and
can only occur if the Line-in NR is turned on in
DISPLAY > VIDEO menu before starting to
record, Unit hangs after trying to record from Line
Input to DVD
If the "OK" or the "Return" button on the
remote is pressed at this time, the unit will
hang and the front display shows scrolling
"ooo...".
Unit can be recovered by pressing the RESET
button on the front panel.
to correct it Download the improved firmware from
Panasonic Web site and update the
unit
May 13, 2013 | Panasonic DMR-EZ28K DVD Recorder
I cant get my dvd player to power off so that my tv can come back on. I keep hearing the dvd player make a sound but off is constantly displaying on it. I cant get my tv back on and i keep hit the power...
Remove the power and manually turn the loading mechanism to eject the DVD whichis struck up inside the player. Now if the DVD circuit seems to hang up again you can disconnect the connector to the main board to switch on the TV.
Jul 21, 2011 | Sony Televison & Video
We purchased our DVD player about 3 mths ago and everything was fine, then about a week ago after the kids were watching TV and went to record a show the DVD turned itself off. Now when we turn on our DVD...
If you only purchased it 3 months ago it should still be under warranty.
Just bring it back to your place of purchase for a refund or exchange.
Apr 16, 2011 | Televison & Video
Dvd player gives unknown disc
thats because its region locked..do the following:
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
do let me know if it worked.
Oct 29, 2008 | Philips DVP320 DVD Player
Gets hang up at the Welcome screen does not display menus
did u try holding down the power button for 10 sec? now if u could help me ive been trying 2 delete songs but i have kbnow idea how could uhelp me ? emaail abbott352@gmail.com
Jul 26, 2008 | RCA Lyra RD2765 MP3 Player
Hangs/ "wrong disc display"
yea take your DVD player to a repairman your micro could be your problem.good luck.
Apr 06, 2007 | Coby TFDVD7050 Portable DVD Player with...
DVD gives split image
Progressive scan is turned ON...find it in your menu and turn OFF....GJ
Mar 05, 2007 | GoVideo DV2150 DVD Player/VCR
Onkyo DV-SP501 DVD Player Logo
Top Onkyo Televison & Video Experts
Steve
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
