Question about Broderbund PrintMaster Gold Version 18
Want to print 3 different 5x7 cards at one time
I would like to update my receipe file and would like to print receipe cards. I have tried everything I could think of to make 3 different cards. If you go into the program and type a 5x7 it makes 3 cards the same on the sheet. I really would like to make 3 different ones. Help Becky
  • 73 Answers
Set the layout in the screen (according with the layout of the paper / cards you are going to use) --> set the 3 different texts (receipes) in the screen according with this layout--> print
Posted on Nov 04, 2008
Not a problem,but I own the canon pixma 310 and I'm not sure how setting it up to print photos is different than regular document printing?
Hi! here is your solution. 1. Select your image. 2. Click your mouse i.e. right click. 3. Select Print. 4. There are many size for example 4x6 5x7. Chose your size you want to print. 5. Select Photo plus Glossy paper. 6. Press print. thanks
Sep 05, 2011 | Canon PIXMA MX310 All-In-One Printer
79.060e on HP5100 laser printer
The printer detected an error. The numbers (xxxx) indicate the specific type of error. Turn the printer off, and then turn the printer back on. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears when you use a certain software application or print job, contact the software vendor for assistance.) If the message persists, try the following: 1. Cycle the power. 2. Reseat or replace the interface cable and cycle the power. 3. Download the latest firmware image (if available-the firmware download is not available for some printers) from http://www.hp.com and use HP Jetdirect or another appropriate utility to update the printer. 4. Remove the DIMMs one at a time and cycle the power. 5. Try using the parallel interface, if possible. 6. Remove the EIO cards from the printer and then perform a cold reset. 7. If the error persists, replace the formatter.
Aug 15, 2011 | HP LaserJet 5100tn Printer
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
Faded printing on 5x7 size paper
Sure. One of the papers is probably clay based (Shiny) and one is rag based (rough and dull). Clay based produces the most vibrant inkjet images and rag based produces the best laser printer images. I bet the two papers are different in composition. I see this all the time.
Mar 29, 2010 | Canon PIXMA MX310 All-In-One Printer
Cannot print 5x7 photo on Photosmart D7360,
if you dont hvae 5x7 option you can creat your won setting open printer adn faxes ...>goto file ..>server properties there you can creat it......
Oct 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Cannot print 5x7 photo with i550 printer. What do
The i550 is capable of printing 5x7, the print software you are using may not be capable. The paper is loaded in the feeder lengthwise all the way to the right. If you are getting error codes, that's a different story.
Aug 13, 2009 | Office Equipment & Supplies
Is it possible to print 5x7's with the kodak esp5
Print from your computer :
open the picture you want to print
go to :
File
Print
Properties
another windows will pop up and under general you will see different print size and you can chose there the different paper size and print size.
Apr 11, 2009 | Kodak ESP 5 Printer
Print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
Broderbund PrintMaster Gold Version 18 Logo
266 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
