Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1989 fxstc electrical
Went to start up and turn twice, heard hard start then a clank and no longer had power to dash. Battery checks good and if I put jumper cables to it panel light however won't kick over. Any suggestions?
  • 216 Answers
I'm thinking your starters bad. You might have blown a cuircut when u forced it.
Posted on Nov 03, 2008
1989 ford escort turns over but wont start
if all you did was this...and and put a new battery in and still wont start...if you have went thru your plugs..wires..distributor..ignition coil...made sure your getting spark..if not..check your relays and fuses..preferebly one that deals with spark and timing for injectors..if everything is fine to that point...then try a crankshaft position sensor...it tells the pcm timing for fuel injectors and fire to the ignition coil...hopefully this helps.
Mar 31, 2013 | 1989 Ford Escort
06 Colbalt Electrical System Dead
I would go to the positive terminal on the battery anjd check for black hard build up on the post and inside the terminal. This is lead sulphate and cause a high resistance to any high current flow. Clean both with sand paper until shiny and refit and tension properly. Do the negative also as it will have build up but to a lesser degree. If the battery lead runs through a connection box Check for tight connections there also. As to towing most towers have a wheel rack that fits under the tyres and lifts them clear of the road so it can be taken to to a shop.
Feb 17, 2013 | 2006 Chevrolet Cobalt
Pt cruiser 2002 wont start, good battery, good alt, bad car alarm maybe??
My PT has done the same thing twice. I have found the car will start with my spare set of keys. After starting this way it will accept either set of keys. Weird!
Sep 02, 2012 | 2002 Chrysler PT Cruiser
1999 Crown turned ignition switch to start - heard pop - no electrical power
If nothing works including the lights, something happened between the battery and the fuse box.
There are some fuseable links between the battery and the starter solenoid or between the solenoid and the fuse box.
I'd start with the battery cables and look for those fuseable link wires.
Jul 09, 2012 | 1999 Ford Crown Victoria
I have a 1995 ford mustang v6 3.8 liter automatic, situation- pulled up to a store and got something to drink. went back to the car turn the key over and heard a click and lost all electrical power, the...
check your fuses. I expect its one of you main uses located under he hood. You also have another fuse box under the dash in the drivers side footwell. Check all the fuses and if any are broken and replace if necessary. Further electrical problems will likely need to be diagnosed by a shop.
cheers
May 20, 2010 | 1996 Ford Mustang
1989 Buick Park Ave won't start. Year old starter, battery indicates good, engine doesn't turn over, car was sitting outside in cold weather. Starter does not make any noise. When ignition switch is turned...
Its likely poor connections from sitting i get it all the time; see if the dash lights go out when you go to start it this means a poor electrical connection. Take the battery terminals and clamps; sand them down to shiny and tighten them up and maybe give them a shot of wd40 for good measure(it is supposed to absorb moisture).
Dec 28, 2009 | 1989 Buick Park Avenue
My 89 gmc 1500 will not turn over
Did you check your ground wire?If ground is good check to make sure your solenoid wire which is purple usually if it is broke if not get a test light and have someone turn motor over to crank position and check if power there if so more than likely ground problem.If solenoid has no power move to fuses under drivers dash..
Mar 28, 2009 | 1989 GMC Sierra
Car won"t start..acts like the battery is dead .
possibly the alternator. or even a bad connection on one of the wires
Jul 19, 2008 | 2000 Kia Sephia
Lands Phones Logo
96 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
