Back to:
Tags:
Bosch Classixx WFL 2462 Front Load Washer
Active control light flashes (by 2 users)
posted by darrena on Sep 24, 2006
The problem is with a Bosch WFL 2450. It fills with water but stops at random times and the 'active' light flashes. The cycle continues when start is pressed. The supply taps are ok, the hoses are not kinked and the strainers are not blocked.
Any ideas please.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Mike H Rees, posted on Sep 26, 2008
Active light flashes press start does not help. Need to turn to turn off and back on. Suspect the waterpump, it makes a lot of noice.
Can you Help with these Washing Machines problems?
Washing Machines
door wont open
Washing Machines
washing machine not spinning
hello, my Bosch Classixx 1200 washing machine door will...
turns without engaging selected items
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
