Question about Microsoft Xbox 360 Console
Disc tray will not close
While i was playing Fallout 3, my xbox 360 started making loud sounds that did not sound good at all. so i turned it off. then, i turned it back on, to take the game disc out, i took it out, but when i pressed the button to close the tray, it closed, but it just comes back out again. even if i turn the console off, the disc tray will remain open.
  • Anonymous Mar 07, 2009
    me to this is *** as ****. only i was play gears.
    i just did the manual eject but im not sure it worked. ill report back if it works.
  • 67 Answers
Make sure the Front of the xbox 360 is not lose i could keep the tray from closing properly or the gears could be jamed with somthing try it if it dosen't help u might have to send it in
Posted on May 29, 2009
Open it up there could be something stuck in it or something
What the hell this happened to me today!
Posted on Nov 03, 2008
    Problem Solver:
  • 6 Answers
Unplug your 360 from the main power source and make sure there's is nothing that may be preventing the tray from closing completly
Posted on Nov 02, 2008
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
It thinks some game discs are DVDs
FIRST GET A HAMMER THEN BANG THAT **** 17 TIMES THEN GO BUY YOURSELF A OTHER ONE.
Mar 21, 2010 | Microsoft Xbox 360 Console
Fallout 3 freezing
Well your disc is officially garbage because it's for sure scratched. Don't bother trying to fix your game disc. Do what I did. Go to sellitbroken.com and sell your game to them. They will give you good money for it.
Jan 31, 2010 | Bethesda Softworks Fallout 3 for Xbox 360
XBOX 360 cd rom is not reading discs
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
Jan 13, 2018 | Microsoft Xbox 360 Console
Why when i turned my xbox 360 it came up with a xbox 360 logo and it said action not avaliable and when i played a game it made it a loud sound and when i took the disc back in it worked fined is that a...
Please give more detail!
No game in tray it says action not available?
The Loud Sound, is this over the speakers or does it sound like the disc hitting the laser, or is it just the disc spinning normally?
You may want to try and disable autostarting to the disc, set it so when it turns on it loads the dashboard. Also if you are burning games, and your ixtreme version is wrong for that game type, i.e. wave 4 on ix1.4, you would see errors like this
Nov 15, 2009 | Microsoft Xbox 360 Console
My Xbox 360 makes a loud humming noise while i play
The Xbox 360 does not like to be moved when playing a disk some of the mechanics may have misaligned or slightly out of sync this may be reason the DVD drive is making those sounds.
I strongly recommend you remove any visible dust from the 360 especially the sides and air vent holes using a vacuum cleaner. Once youve cleaned it place it horizontal (never on carpet) on a flat surface well ventilated away from other devices that generate a lot of heat.
As for the 'shredding sound', place in **** game into the 360 when it starts to make those sounds again gently tap the 360 on top (where the DVD drive is) until it stops making that sound. This doesnt always work but has for me and many others.
My experience tells me that dust can build up not only inside the 360 but also the drive itself which can lead disc read errors and the sounds and you mentioned.
Remember DUST and HEAT is the 360's biggest enemy and can cause RROD, 1 Red Light Problem, and disk errors.
Hope this helps..good luck!
Jul 27, 2009 | Microsoft Xbox 360 Console
Fallout 3 Freezing Problems???
Fallout 3 freezing is an unfortunately common problem. A lot of people have reported that clearing the game cache on your 360 will fix it, so that's what I would suggest you try first.
To do this:
  1. start up your 360, then take out the Fallout 3 game disc.
  2. Hold down the A button on the Player 1 controller
  3. Put Fallout 3 in your 360, then load the game
If this doesn't fix it, the next thing you could try is to clear the system cache. This will clear the entire cache for your 360, including the automatic updates (though downloaded content, save files, and user dats will be untouched).
To do this:
  1. Navigate to System > Memory
  2. Highlight the hard disk in the list and press Y
  3. Press X, X, LB, RB, X, X
If done right, you should see a message asking, "perform system maintenance?" Proceed with this, and it will clear all the cache data out and revert Fallout 3 back to version 1.0 (it should ask you to update once you load the game)
Hope this helps - I've had my share of frustration with Fallout 3 glitches.
-Nick F.
Mar 03, 2009 | Bethesda Softworks Fallout 3 for Xbox 360
Xbox 360 will not read disc and is making a weird noise
Is it doing this while the disc is in the drive? Also does it sound like a loud rattling sound?
Oct 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
128 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
