Question about Canon PIXMA iP2000 InkJet Printer
Servicing of C 46 Epson Printer
I have problem with the above printer. Error message displays " end service" and both the Red and Green light alternatively glow.
  • 4,041 Answers
Canon PIXMA IP2000
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
All the Best Pineworks
Posted on Feb 18, 2010
Epson C88 will not print, is flashing both paper and ink lights
I think you need to reset the counter, you can either take it into a epson service centre & have them reset it, or download a programme online.
you just need to google it, just type in service reset C88 that should do the trick.
Nov 06, 2009 | Epson Stylus C88 InkJet Photo Printer
The status of my printer (epson stylus c45)is idle. There's this yellow exclamation point before the message-Service Required then...inside the dialogue box it's written that Parts inside your printer are...
You will need to get it serviced at an authorized Epson Repair shop as the parts that are at the end of service life are not user servicable. With the price of printers today it would be cheaper to buy a new one with updated technology than to try and have this one refurbished. Hope this helps.
Jul 19, 2009 | Computers & Internet
Green & red light is blinking
If you try to print and it say "end of service life ........thing" . You have to reset the printer counter to 0 count.
Use a third party software for this, key in in your web search bar " epson reset software" the upper most link is the one, try to read the procedure.
Hope you get it easily.
May 25, 2009 | Epson Stylus C43SX InkJet Printer
I have an Epson R320 Printer. error message;service required. printer parts are at end of service life see service manual for details. I can not find anything in the service manual about this. This printer...
This message indicates that your waste ink pads are full and require replacing. Replacement is costly, messy and requires the printer to be taken completely apart. Most often the counter has "jumped" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Apr 14, 2009 | Epson Stylus Photo R320 InkJet Printer
Service ink reset error epson R265
Try to find out how to completely reset your machine through your manufacturer
Feb 27, 2009 | Epson Stylus Photo R300 InkJet Printer
Initial Charge message not seen
Sounds as though the printer is defective.
Call or email Epson Tech Support.
Feb 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
EPSON PRINTER NEED SERVICE
your printer wast pad is full so the printer need to be reset if you dont have the tool let me no
Nov 02, 2008 | Epson Stylus C46 InkJet Printer
EPSON PRINTER R22O
Hi-
yes actually there is. the parts its talking about is the inkpad, you can send this over to an epson certifies servicer in your are to have inkpad change and they will reset the counters for it. go this link and look for a servicer near your place
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
or you can contact epson at 562-276-1300
pls rate as fixya if helpful. thanks!!
Jun 21, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson stylus c45 (Problem)
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C45 Service Manual". You will often find them
for sale very cheaply on E-Bay.
Jun 14, 2008 | Epson Stylus C46 InkJet Printer
EPSON PRINTER R22O
display This massages Parts inside your printer are near the end of their service life.
See your printer documentation.
Nov 08, 2007 | Epson Stylus Photo R320 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
43 people viewed this question
old marine
old marine
