Question about Intel DG965WH Motherboard
No boot my pc no longer boots after changing the case. i have tried removing the board and powering up with only the power supply , ram and board still no boot or beeps. i do get 3 beeps if no ram is installed. i aslo tried removing the bios battery for over 20min and replacing. the system worked fine when in the old case.
  • 165 Answers
Check to make sure you don't have any extra standoffs under the motherboard that may be shorting it out.
Posted on Jun 20, 2009
My emachine T2958 would not boot. the fans run but no bois nothing. i realise on the mother board alight is on by the letter F.Is it the motherboard ? help please
A good way to tell is disconnect your hard drive's, & CD/DVD ROM's power & data cable. Try to boot.
If you get the same results then you can try & remove any PCI cards from the board, remove your ram stick. Try to boot. If you get an error beep because you are missing ram than this is good.
Replace 1 ram stick back into your motherboard & try again. If it boots then you know the other stick is bad.
If removing all the non-essentials from your motherboard doesn't work then all you have left are the motherboard & power supply. A simply power supply tester or spare power supply will tell you if it is your board or not.
Jul 16, 2012 | eMachines T Computers & Internet
The yellow light comes on inside but the computer won't come on neither does it beep?
First remove any power cables and batteries(if laptop) from your system and hold down the power button for 15 seconds.
Plug the power cable back in & attempt to boot.
If this does not solve your problem then you will need to remove all non-essentials from your system.
If laptop, this simply consist of battery, ram, optical drive & any other removable bays or devices. Unplug all cables except the power cable & attempt to boot.
If desktop, you will need to remove any cables plugged into your computer except keyboard, mouse, power, video, sound, & network cable. Open the case & remove any PCI cards, except video cards, unless you have on-board video, unplug the data & power cables going to the optical & hard drives. Now attempt to boot. If you have no luck you can remove your RAM sticks & try again. If you get an error beep warning you about no ram then you might have a bad ram stick. If none of the above works then you may have a bad power supply or motherboard. Power supplies are pretty easy to test with tester or use a spare.
Jul 16, 2012 | Dell Computers & Internet
D600 wont power up
Try removing the battery and boot on the power cord sometimes the battery shorts the system so it will not boot if it does boot then you need to replace the battery it could be the battery is dead and your power cord is bad check and make sure that is not the case if the power cord is good then I would look into replacing the mother board you can find a replacement on Ebay or at dell .if you have to replace it do a google search on hot to replace the mother board on a Dell latitude D600
and you will ba able to get step by step on how to disassemble it
Aug 28, 2011 | Dell Latitude D600 Notebook
When i power on the PC no beep, no image, led inside PC lights ON OFF green light Please help me (my PC is HP- P4SD motherboard)
when PC cannot boot there is probably failure on installation RAM, VGA (external), or Power Supply. in your case (no beep) maybe it is your power supply don't have enough power to boot or its already damaged. try to another power supply with higher voltage (watt), or change with the new ones. hope this useful, regard riyan.
Mar 30, 2011 | Intel P4 System Configurator (P4SDRAM1) PC...
PC will not power up, and power supply is working. The Mother board is in a HP Pavilion a1473W
A few things to check:
Firstly, scheck that there are no blown, or bulging capacitors on the motherboard, this board had a tendency to fail due to these going.
Then, remove all non-essential peripherals and leave only one ram module in the board, try to boot, if it does boot, replace all in turn, booting each time you do so and identify the faulty component.
If it will still not boot, listen for any beeps you may get.. note them down and if there are any, repost your query.
Things to try now:
Remove the cmos battery, leave out for 30 seconds and then replace, try to reboot.
Then try removing all the ram and rebooting with no ram to see if there are any beeps. If it does beep there is the chance that there is still life in the board, if not, the board is probably dead.
Finally, remove the board and power it up on an antistatic surface, using a temporary switch to trip the motherboard pw switch ( or use a screwdriver on the two terminals briefly). If it does power up now, check the switch from the case to the motherboard for breaks or damage, replace / repair and rebuild the tower
Jan 28, 2011 | EliteGroup RC410L/800-M2 (V1.0)...
Inspiron 6000 starts to boot but then shuts down after only 10 seconds. New Battery, power supply measures ok. Caps lite is on.
Try reseating the RAM memory modules, see if any change.
If no change, remove, battery, Drives, Wireless card and RAM, see if the system will run longer or give an error code. If something changes, add 1 RAM module and try again. If the system runs, then add items back one at a time until you determine the faulty item.
If the system issue doesn't change, odds are a motherboard problem. Motherboard are about $100 on Ebay
Dec 06, 2009 | Dell Inspiron 6000 Notebook
Dell gx270 mother board power supply proseccer fan automatic running but power switch is not work how i find plz help me
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Jul 06, 2009 | Dell Computers & Internet
L440Gx server board do not boot
1: Check wether the on/off button on your power supply is turned to on.
2: Check your cables. Try switching with those from other pc's.
3: Check wether all the connections from power supply to the mainboard/ram/video/harddisk are OK.
Hope this helps,
Feb 18, 2009 | Intel Server Board L440GX (KMS440GXTPAK10)...
Ms9317e does not boot
you better go to last resource directly:
1. disassemble the system completely and take the mother out the case... Give it a perfect cleaning.
2. place the mother over a wood table or something like that (mother without anything but the cpu).
NOTE: if you are running onboardvideo do not connect external video board... if you are using external videoboard and do not have onboard video, you might have problems on the board... so you could need another one).
3. just connect RAM and power supply (the power supply must be out of case, placed over the table too and well connected to mother and to power line.
4. power on the system by jumping the pins on the motherboard... you can find them under the identification front pannel or something like that deppending on the model... just the pins that normally you attach to the cables that leads to the buttons on the front of the case. (use a screwdriver and do not touch anything on the motherboard with your hand if its connected to powerline).
then, and after trying vga adapter if you have one and trying rams one by one in different socks... you will know that if the system never boots up, you have hardware problems, either on mother, ram and less probably, power supply or very rarely cpu...
g luck, in this cases... better go live chat...
Mar 21, 2008 | Matsonic MS9317E Motherboard
Booting problem
try these two alternatives:
1.try to clean or change the slot of the memory
2. check on th power supply you put on your motherboard for the new board there are the socket for the power to be placed on the otherboard
Dec 22, 2007 | Biostar P4M890-M7 Motherboard
Intel DG965WH Motherboard Logo
169 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
