Question about Sansui HDLCD-2600 26 in. LCD Television
How to an homethether to the lcd
Were is the audio out for conneeting the home therter
  • Sansui Master
  • 520 Answers
Sorry, the HDLCD2600 only has a coaxial audio out jack and only works with digital signals from the digital tuner or HDMI jack. There is no analog out.
Posted on Nov 04, 2008
How do you connect a Home Theater System to a Sharp 60 Inch LCD Aquios TV for Audio?
Use an RCA cable from the TV's audio out to the AUX in the home theater unit.
Oct 19, 2014 | Audio Players & Recorders
Can we connet settop box to home therter
consult owner manuals for both to see if compatible or not.
May 24, 2012 | Televison & Video
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
source from
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
Hi, our family is attempting to hook up and install a frisby 5.1 digital surround sound home theater system to our spectroniq pltv3250 32 lcd tv without success. As instructed, we are using all the correct...
Pl check all speaker connection is ok after that take AV out of your LCD Tv & connect with your home theater system for audio input in your home theater system
Jan 21, 2010 | Spectroniq PLTV3250 32 in. LCD TV
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
No audio from tv to home theater
at the back off tv there is a connection labelled audio output you need to connect that to any available iput of your home theater receiver then use that for tv watching
Nov 12, 2008 | Vizio L32 32 in. LCD HDTV
Locate the Audio output on your TV and connect it to ur X530 Audio input. Locate ur Audio output (exa. AUX-OUT, MONITOR OUT, ETC..) on ur Home audio then connect it to ur X530 audio input. Goodluck
Aug 11, 2007 | Logitech X-530 Computer Speakers
Sansui HDLCD-2600 26 in. LCD Television Logo
49 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
