I have a Mitsubishi 1080 HD Medallion 48" projection TV that was purchased about 5 years ago. The green light next to the system reset button is flashing quickly and the set will not turn on. I have tried unplugging and resetting the tv as the dealer and manual suggest, but this does not help. For a while it was turning on and was okay for a week or so. Now it won't turn on at all.
  • jejamesw Nov 02, 2008
    The blinkiing is continuous.
    What would it actually cost to have an authorized repair service come to the house to replace the 4 caps?
    Genius:
  • 1,011 Answers
Sir,
On those TVs it is normally a bad DM module board/convergence check out this forum it may help you a little more....
http://www.hdtvoice.com/voice/showthread.php?t=20219
4 bad capacitors in the DM module is not letting your TV set download it's software. They must be replaced to fix it.
Done several of these...you'll need (4) 1000uf caps at 35 Volt rating, and a TV Tech to install them.
Get a Mitsubishi Authorized servicer out to your home.
And you should not need a DM module to fix it....I've only had ONE out of 30 that required the DM module...but that's because the customer waited too long to get it fixed.
thanks
good luck
Posted on Nov 02, 2008
    Guru:
  • 1,894 Answers
Can you tell me how many times does the light blink?
if you help us with the blink code it wil be very useful for us
  • dewan nafees ahmed Nov 02, 2008
    The constant blinking green light means that the TV is not booting up.
    This is a common problem on this set.You need to remove the shield from
    the DM board (standing upright on the left where the DTV RF connector
    is)and inside you will see the four leaky capacitors (1000 MFD 16
    VOLT)replace them,plug the TV in and wait 70 seconds for the blinking
    light to stop,then turn on the TV.The hard part will be removing the
    board from the TV(lots of screws and connectors,takes time)
    You must do some checks first:LED does not stop blinking after plug in.
    Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts
    at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present
    suspect the DM PCB part # 934C067001 LED does not stop blinking after
    plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM
    PCB, if they are bad replace them with part # 181P734030 (680 UFD 16
    V). LED stops blinking after 70 seconds of plug in but will not power
    on. This model is equipped with a keyboard lock feature; this can be
    mistaken as a no power condition. To unlock the keyboard press and hold
    the "menu" button on the front panel for 10 seconds . LED stops
    blinking after 70 seconds of plug in but will not power on. Check for
    3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low
    suspect problems with the switches/buttons on the Control PCB part #
    935D736001. LED stops blinking after 70 seconds of plug in but will not
    power on. Keyboard is not locked and key inputs at connector RF pin 4
    and 5 check good suspect the E2P PCB part # 934C061001.
    Just click below for more information.;
    http://www.fixya.com/support/t838883-mit...
    Hope it may help you ;
    thank you
    approx 200$ or less than that sir..
    it would be great if you kindly "accept the solution" .. :)
    thank you
Mitsubishi medallion hd 1080
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Mar 27, 2014 | Televison & Video
Have a Mitsubishi Medallion HD 1080 Model WS-48413 which won't turn on. When I push the power button on the remote or on the tv itself, a green light comes on for a moment and a clicking sound is heard to...
~ Check the lamp hours ~ Normally it is 200-400 hours lamp life ~ BASIC USAGE: 8 hours/day ~ Reseat the lamp~ Consider replacing the lamp or it could be an Internal Problem
Jul 06, 2010 | Mitsubishi WS-65413 65" Rear Projection...
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
Jun 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
Green light flashes on my 65 mitsubishi 1080 medallion. reset button doesn't reset it and light continuously flashes
You need to replace 4 capacitors on the "DM" board. They are 1000uf and 16v. The board is located under a metal shield on the left side of the set (looking from the rear).
May 12, 2009 | Mitsubishi WS-65413 65" Rear Projection...
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
May 30, 2008 | Televison & Video
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
