The adapter's Syscon detects a short circuit. It might be within the adapter itself; or with your system. Contact the authorized service centre in this case. If you have an other adapter, load it with. By this way, you can get an idea about the faulty unit. Electro help
Call DELL support. Doesn't sound normal. There is Standby and Hibernate modes; neither of which would require you to unplug and plug-in the power cord in order to start the machine.
Dell support will have you run the Dell diagnostic at startup which will detect hardware problems. Or you could run it without calling...
Unplug power and remove battery
Press and hold power button 20 seconds
Replace battery, plug power cord in
Hold down the "Fn" key (to left of space bar)
Turn power button on while still holding Fn key
When diagnostics begins, let go of Fun key
Note any errors; let Dell know your findings
Hello It will be best to get it repaired by the authorised service center for Lenovo at your twon. Its battery charging section circuit [inside the motherboard] is faulty.
yes, if no cartridge into printer, device will appear error message, but if have cartridge into printer, printer still appear message, it most likely your cartridge problems
Certain models talk to a chip in the adapter, sounds like this one has gone bad. At this point you can live with, buy a new one or pick up a used. This is a fairly popular model and you should be able to locate one from a dead laptop.
Uninstall the program from your computer. Plug in your printer first replace with new cartridge making sure to remover the film on the cartridge Then plug in patch cord to computer, program should reinstall if need be you may have to have your disk that comes with the printer. Hope this works, Printers are going for very cheap I would suggest buying a new one if this does not work.
