Just wont work...mouse is fine..
SOURCE: Acer 5100 keyboard issue
Dear friend.. the same happened to a customer's laptop.
I suggest you do the following:
First, try to scan your harddrive for viruses in another computer (you can buy a cheap 2.5" USB enclosure for your drive and use it as an USB drive). Once you do that, clean from viruses.
Next step is reinstall the disk and boot the machie again.
If it's a virus problem -as it happened to me- the BIOS block itself and nothing responds, so, you'll have to cheat BIOS.
Plug a flashdrive (any kind) and wait to windows recognizes and installs it. Once it's done unplug it and plug a USB keyboard and/or mouse and wait. Once you have control power off the system normally (THIS IS VERY IMPORTANT TO UNBLOCK THE BIOS).
Next time you power on your computer, keyboard and mouse should work great.
Hope it helps.
Greetings, Pablo.
PD: One advice... you will probably have to reinstall windows. And finally try linux... this won't happen with it.
SOURCE: mouse touchpad, keyboard, and usb drives will not work
i just removed the battery. it works too.
SOURCE: Acer Aspire 5100 Notebook
Try booting your computer from CD ROM with the OS CD/DVD already inserted and when prompted just try repair. If that does not work re-install the same on the same 'partition' assuming it to be C by deleting the the windows system files only. While doing so keep the internet on and immediately after the basic version of the OS is installed and the m/c boots-up for the first time, go to the official website and download the latest drivers for every component like toch-pad, keypad, display, audio, etc.(i.e. almost all the drivers)
SOURCE: My acer 5100 aspire laptop's mouse and keyboard
I think you have disabled them.
There should be a key to enable mouse and keypad.
external keyboard will work but not internal..
