FixYa.com
Tags:
Uniflame 200209 Open Flame Patio Heater
Pilot light lit but no heat (by 3 users)
posted by bigboy98349 on Sep 24, 2006
When trying to fire up my patio heater the pilot light lights but goes out when trying to turn gas supply knob to either high or low heat. Is there a way to find out if the thermocouple is shot. It has been cleaned, used compressed air.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Kmsutra, posted on Mar 11, 2008
I have a similar problem. I turn the **** and press it. The ignitor works and the pilot lights up but does not stay lit. I have to try this several times (15/20 times). Sometimes it does not light up at all. It's done this from day one so cleaning the venturi is not an issue. Am I doing something wrong?
Comment by Guest, posted on Mar 07, 2008
I dissasembled the main gas valve/regulator and think my thermocouple is not holding open the plunger after the pilot is lit. Any suggestions?
Best Solution
posted on Oct 15, 2007
Helpful (85)
Buffalo12980
Rank:Wiz Wiz
Rating: 84%, 762 votes
the pilot's millivolt generator may be at fault.  if you have a meter that is capable of measuring a very small DC voltage, connect it up to the very end of the thermocouple and the copper cappillary. the thermocouple has a welded bead at the very end inside that generates a small DC voltage. Same principle of a J-K thermocouple. Iron constintan  - two dissimiller metals where joined together produce a voltage when heated.  the thermocouple actuates a millivolt electromagnet inside the valve to keep the valve pellet open.  no voltage there it won't actuate the electromagnet.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 04, 2008
Not Rated (0)
BBQmaster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This is the most common question and issue around these heaters. The Pilot Assembly needs to be cleaned out. See steps 7 through 14 here.
http://ww2.bluerhino.com/br/Uniflame/pdf/PatioHeaters/15002000CI-IS-103.pdf
Can you Help with these Heaters problems?
Heaters
Manual required
I have a Vulcan Electric Wall... Answer This...
Heaters
Solar power cell
I need a solar power cell to... Answer This...
Heaters
Ptac grille
Did you ever find out about the... Answer This...
Heaters
vulcan oil heater
My heater has been working fine... Answer This...
Coleman Gas Heater for home
We have a coleman gas heater,... Answer This...
Repair Service
Find Heater Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
