Question about GE Dishwashers
GE GHDA485N00CS model dishwasher has no power
My GE dishwasher has no power. It's connected to a wall power switch in the kitchen. I've tried flipping the circuit beaker and cutting the power switch off an on. We have not had any recent power outages in the house.
What should I try next?
  • Anonymous Nov 21, 2008
    Me Too!
I have the same problem with my GE dishwasher. The model number is GDS640P-25BA. Any help for this problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.
Posted on Nov 12, 2008
Pushed button for pots & pans and now it won't cancel, what can I do?
Hi Teresa, Step 1
Press and hold the "Start/Resume" button on your dishwasher. This button controls the power for the entire unit and will force a reset of the system.
Step 2
If this does not reset the dishwasher, shut off power to your kitchen using your home's fuse-box. If dishwasher is a built in unit, ie: in a cabinet, this is the easiest method. If your dishwasher is not built-in, you can unplug it from the wall.
Step 3
Flip the circuit breaker switch back on, restoring power to the dishwasher.
Step 4
Press the button again to start up the unit. Whether you reset the system by pressing the button or cutting off the power, you'll need to press the "Start/Resume" button to power the unit back on afterward. Diagnostics will run again, but after a forcible reset, the diagnostic cycle usually proceeds without incident. I hope this helps. David.
Oct 05, 2017 | Dishwashers
I Have gsd422ox6BB Dish washer that all it does is flash the reset light.
Flashing reset light could mean the flood switch is turned on. There could be water in the motor compartment of the dishwasher. To get this water out, you will need to take the dishwasher out from the kitchen bench and turn it side to side a few times so that water comes out on the floor. Make sure the power mains connection is taken out.
If this does not help then the flood switch itself might be faulty.
Check parts on this site.
http://www.appliancepartspros.com/body-parts-for-ge-gsd4220x72bb.html
Feb 16, 2014 | GE Dishwasher Power Board - WD21X771
GE digital timer 15313 has 3 wires, black, blue and green. Wall switch wires have bare, black, red and white from one line, and black and white from the other line. I've tried every combination
It sounds like you are replacing 3-way switch.
Low voltage light? Are these lights connected to 120Volt circuit?
I think you want the GE 15312 timer, instead of GE 15313.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
GE 15313 is for single-pole incandescent light bulbs only.
This is live answer 11-2012
Add a comment for more interaction on answer.
Nov 22, 2012 | Hardware & Accessories
Maytag gold dishwasher model GU2400XTP03 Ser# Fs0606107 Will NOT DRAIN
Hello
Do not open the dishwasher until the cycle completes. A green indicator light on the front of a Maytag dishwasher will let you know the cycle has completed. If you open the dishwasher before the cycle is over, close the door and press "Start/Resume."
Remove the knockout plug from the disposer inlet if the dishwasher is connected to a food disposer. Place the tip of a screwdriver along the edge of the knockout plug, which is on the side of the disposer. Tap against the head of the screwdriver with a hammer until the plug comes loose.
Inspect the drain hose for kinks. Make sure it is not bent or pinched in a way that would impede the flow of water through it.
Use your hands to clean food from the drain in the dishwasher. A buildup of food can block the drain and not allow water to freely flow from the inside of the dishwasher.
Open your breaker box and check to see that the switch that controls your kitchen appliances is flipped to the "on" position. A switch flipped to "off" means your appliance has no electricity. The dishwasher will not drain without power.
Sep 11, 2011 | Dishwashers
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Burners keep arcing even when switched off
Disconnect from power sorce, or flip breaker for oven/stove. Then call GE for a service call.
Oct 11, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
It hasn't been used much and a couple of months ago it ran just fine. I went to do a load of dishes and it is just dead. Nothing is working. I flipped all the breakers to see if that was the problem and it...
flip every wall switch in your kitchen,while having door latched and turned to a run mode of some sort.be sure to check under kitchen sink for any hidden power switches as well.8 out of 10 ge d/w with this issue usually revert back to a wall switch
Nov 13, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher does not come on when power button pushed. GSD5610 model
Check the following to address this issue-
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jun 05, 2009 | GE Dishwashers
We have a service contract with Broward Factory Service. My GE dishwaher went out with eater in it, no power. Checked the panel box flipped switch, nothing. The service tech. said the rinse aid cup leaked...
I was trying to find out if the dishwasher was on a recall list, and I did by calling GE direct. It was not, so the service I have is replacing the rinse aid box.
Thank you,
Aug 26, 2008 | GE Dishwashers
Dishwashers Logo
638 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
