Question about JVC AV-56WP30 56" Rear Projection Television
Convergence off. Repairman said IC and one resistor bad. I am certified for soldering boards. I just finished replacing these parts he listed on my reciept. He also said adjust.. How do I adjust the convergence now with the remote??
Get the remote and go to Menu and go to Initial Set-up and click on the convergence button. You will then be able to line up the pluses in the middle of each color. When they are lined up you are ready to go.
Posted on Jan 17, 2007
Colored lines at top and bottom when tv comes on and seeing double vision in different colors at all times
If your tv is not a DLP the problem is in the convergence, try to adjust it using your original remote control go to the setting menu then to the convergence section. Adjust the red and blue convergence. you should move the red and the blue in up, down and left, right if this color does not move far enough your convergence IC is already defective. Replacing this convergence IC will solve the problem. In locating this convergence IC you should remove the back cover of your unit but be sure to unplug it before doing this. This convergence IC is attached to a large aluminum plate, it is the heat sink, and it has a marking of stk- ### followed by numbers. You can try to pull it out using a soldering iron and soldering pump but be careful you may damage the board and cause much problem to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards.
Aug 28, 2011 | RCA Televison & Video
Convergence color is not converting
Replace convergence IC (location 8c01) which is a STK-393-110. You will need to order an after market market convergence IC (STK 393-110) I have had good luck with this IC. Next, check and replace all the 3.9 ohm 2 watt resistors, that are bad. You can check them with an ohm meter or visually inspect for burns or peels. Resolder the Convergence board, as by now there are many bad grounds (broken solder connections). Be sure to resolder the jumper jacks that connect the board to the next board too.(Under this board are solder traces that adhere to the jumper connections that will snap to the next board.) These would include jumper jacks PM, VU, and PF. Good luck and thanks for asking, show all hands of support!
Apr 10, 2011 | Mitsubishi WS-55807 TV
Mon image est en trois dimensions
Hi Franceg40,
The main reason of your problem is the convergence board gone bad, check first the bad solder joints in the board, you may replace the convergence IC and resistor around or the entire convergence board for your convenience.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
Jun 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
JVC AV56wp74 convergence. Resistor before ICs?
It's recommended to replace all the defective parts first because if you only replace the defective resistor, it might burnt again if the convergence IC is shorted internally. I would also suggest to measure the other low value resistors with multimeter.
Oct 30, 2009 | JVC AV-56WP74 56" Rear Projection...
Red convergence will not adjust horizontally
Only two possible reasons; First the resistors are easy to miss-check-----and also take the chassis up and make sure all the solder connections and foil traces to them are not damaged---Second:The circuit board that plugs into the main board just to the left of the rear IC is the sets DCU---it stores the memory of all the convergence adjustments--it could be bad. The real Question is IS THE CONVERGENCE BAD NOW IN EXACTLY THE SAME WAY AS WHEN IT WAS BEFORE YOU REPLACED THE 392-120 ic's? If it is bad in a different way you may have installed a new IC that is bad---does not happen often but does happen--the most common cause for this is less than perfect soldering on the new parts.
If this has been helpful give me a vote here--I do this for free
etower.766@netzero.net
Aug 22, 2009 | Televison & Video
Auto convergence
Bull!!!!!!!!! i dont think he knows what hes doing....
you can send the board into ptscorp.com have them check it out, it's the board with big black iC stk392-XXX send that one in, you convergence is done thru the menu system.
Feb 15, 2008 | Philips 55PW9363 55" Rear Projection...
Convergence
you have a bad convergence IC and probably one or two precision resistors next to the IC`s that have to be un-soldered and replaced, if your very proficient with electronics you can do the repair if not call a tech. If you decide to do the repair yourself
you`ll need a volt/Ohm meter (to find the bad resistor(s) and soldering equipment to remove the parts and re-install new parts, let me know and I`ll get you part numbers for IC`s, you will have to check resistors and tell me which ones are bad for their respective part numbers.
Nov 30, 2007 | Hitachi 43FDX01B TV
JVC AV-56WP30 56" Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
