Question about Vacuums
Whirlpool refrigerator model #YED22DQXBW01 makes a buzzing sound when running. Sounds almost like a fan noise but ichecked that
Hi My bissell proheat 2x 9500 is making a loud noise when the brushes are moving. I replace both belts and cleaned the brushes. Can you think of anything else it could be.
Hello there,
Try using other brush attachments, as broken bearings in a brush attachment will cause noise. If these troubleshooting techniques do not work, you may need to service the engine.
Remove the filter and bag of the machine and make sure that they are not clogged or full of debris. Clean any filters according to the instructions for your model or replace the bag. Excessive debris will make the engine run noisily.
Inspect the hose of the vacuum and remove any large debris that may be clogging the inside of the tube. Large amounts of dust, as well as stones or other hard materials that bounce, may cause a loud noise in the engine.
Remove the housing that conceals the engine of your machine and inspect the fan for damage or clogging. Remove any dirt or debris that may hinder the movement of the fan. Inspect the fan for any damage such as bent or excessively sharp blades. Replace the fan blades as needed; contact your vacuum manufacturer if the fan is damaged. The replacement part will include instructions.
Tighten the fan with a ratchet if it is loose on the assembly. A loose fan will make a rattling sound as the motor revs.
Wipe dirt and dust from the frame of the engine. Large quantities of dirt or dust around the motor can cause it to overheat, which can cause vibration and loud noise.
Look for corrosion around the engine. If the engine is corroded, it must be replaced.
Grease the bearings of the engine if you hear a grinding noise from the vacuum. Greasing is often performed through ports in the engine, or by removing the bearings. However, the actual greasing method is model-specific. Consult your owner's manual or send the vacuum to a service professional for this service.
Inspect the inside of the vacuum cleaner for other worn parts or broken pieces. Worn or broken pieces can cause loud noises to occur. Remove the broken part and order new materials from the vacuum manufacturer or take the machine in for service.
Hope this information was helpful to you. All the best. Elect_Comp
Sep 05, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Have a bottom mount viking refrigerator, making a loud noise and the alrm is going off for the high heat
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 05, 2011 | Vacuums
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My wife sucked up a small metal object and now it makes a terrible noise it doesnt always it comes and goes
sounds like it got in the fan housing, either a blade is broken or off balance...Make and Model?
Dec 02, 2009 | Vacuums
Noisy brush roll
To me this sounds like the roller could be worn, it may be time to replace, or have it replaced with a new one. Make sure that your machine is off and check by wrigiling it around, if there is exessive movement you have found your problem.I hope this helps.
Nov 04, 2009 | Vacuums
Simplicity freedom model f3300 makes loud noise when running.
sounds like the fan might be broken in the motor
Oct 02, 2009 | Vacuums
Loud noise when running.
Bad bearing or fan in the motor is most likely the problem. You would have to replace the motor.
Mar 02, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
