Keurig B100 Coffee Maker Logo
Posted on Feb 24, 2018
B100 not heating water
I have a keurig b100 and the red not ready light is flashing and the water fill line indicator light is red. i know that it is not heating the water (i dont hear that noise) I bought it used and the person told me that they turned it upside down to drain it. do you have any suggestions?
3 Related Answers
Anonymous
  • 13 Answers
  • Posted on Jun 12, 2007
SOURCE: Keurig B100 flashing not ready
I need to Know What is the color light in seeht gauge tube, Yellow Flash Need to be descale, if red solid or flashing is a heating probleme. If red flashing in seeght gauge tube is usaly the temperature sensor probe is fail. and for the moment i Have not found similar parts to replace but i work on it.
Anonymous
  • Posted on Nov 29, 2007
SOURCE: keurig b100
I think that the unit senses its emptiness via an optical device that triggers when the red indicator ball hits the bottom of the tube. It could be that the tube is dirty from deposits (calcium or whatever,) fooling the B100 into thinking the ball is still at the bottom.. Basically you'd have to open up the machine and see whats what, the tubes can be cleaned but if it is a defective sensor you wouldn't be able to get a replacement, but you could probably jury rig a way to defeat the sensor itself.
The units are serviceable if you are handy, but it isn't as simple as replacing a fuse...
[email protected]
Anonymous
  • 78 Answers
  • Posted on Nov 09, 2009
SOURCE: keurig b100 does not shoot water in the K-Cup, It
Either it is scaled up and needs to be cleaned or the air pump is bad.
Keurig lights flashing Add water heating
ADD WATER!!!
Or is there some other problem that you don't describe, or something I am not understanding?
1helpful
My Keurig says not ready, water won't stop coming out. when it reads brewing, it stops.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
We are trying to get it started for the first time and the blue light is constantly on, but will not flash.
heatman101
My keurig seems to be heating the water all day???? normal [email protected]
Keurigs are ment to have water at the ready... otherwise... you might as well get a Mr. Coffee...
any Mr. Coffee will brew a cup of coffee... use a heaping teaspoon and add 12 oz or water...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
1helpful
I just bought a keurig model b100 an the water does not come up the tank into the brew cup an was wondering how to fix it
check inside if the water line is not pinched . you may need tools a cross point screw driver and such
Keurig b100 does not shoot water in the K-Cup, It
Flashing Blue Light
I have found that if I turn off the machine for a few seconds and turn it back on, the burner seems to re-energize strongly and the water heats and a few minutes later, it seems as good as new. I know that this is not the the technical solution to the true underlying problem, but it keeps my old machine in the game.
Can I hook up a water supply to a Keurig B100 brewer?
The B100 is a pour over unit and the drain is just that.. a drain directly connected to the tank... In order to have plumb feature the machine would need a fill solenoid attached to a float.switch through a circut board of sorts...Hope this helps
Robb
Keurig b100
[email protected]
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
