Question about Whirlpool LER8648P Electric Dryer
My dryer will run but won't heat
I have a 20 year old whirlpool drier (le68oooxtno) that will run but wont heat.  THE PRODUCT LISTED BELOW IS NOT THE CORRECT MODEL NUMBER, THE PRODUCT NUMBER FOR MY DRYER IS NOT LISTED!
    Genius:
  • 2,920 Answers
You either need a new heating element or limit switches
Posted on Nov 02, 2008
Drier won't heat
try replacing hearter wire under drier
Apr 08, 2012 | Whirlpool Dryers
Drier works just no heat. need to know where the
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 25, 2010 | Whirlpool Inglis IP8200 Dryer
Td 4212 w Drier is not heating
Check if it still turns but no heat. If it's a kenmore or whirlpool, it's like a fuse in back of dryer. I would need mor info if it's not these models
Jul 28, 2009 | Zanussi TD4212W Electric Dryer
Drier shuts off
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer'circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Dec 19, 2008 | Whirlpool LGR5634L Gas Dryer
Dryer wont spin
Take the back off  of the drier after unplugging and the beklt goes from the motor pully all the way around outside of the the drum.You can't miss it. Most of the Kenmore drier belts are the same. WE have apliance repair parts stores locally.If you also do , go to the store with the old belt and match it up.
Dec 19, 2008 | Kenmore 63942 Dryer
MY drier heating element shows 9 ohms continuity, it also shows 120 volts into and out of it when the drier is running. But the heating element wont heat up?
Have you checked the voltage at the outlet? You're supposed to read 220-240 VAC at the heating element. Your dryer heating circuits require at least 220 VAC to work. The motor, however, only uses 120 VAC. That's why your dryer may be running, but the heating circuits aren't heating. I would go back and check your outlet. You may be missing one leg of the 220 service, or have a loose, burned, or broken wire in the plug or terminal block (on the back of the dryer). Let me know what you find. I hope this helps you.
Oct 17, 2008 | Whirlpool Dryers
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LER8648P Electric Dryer Logo
127 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
