I have just replaced the battery in this ups (full charge at 12.7VDC) and after initial power on of the unit, 4 sec later it clicks to yellow and shuts off, all fuses and breakers check out and I am unsure if its a relay failure or IC system problem.
hi, i would say ic problem, but check the battery connections-make sure they are not somewhat loose,clean them, and try again. hope this helps, good luck! glen
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Energizer ER-HM650 UPS System
One side of my Energizer 650VA Broadband Battery Back-up system is not functional. The other side...
(More)
One side of my Energizer 650VA Broadband Battery Back-up system is not functional. The other side is. What's wrong ?
The backup side of my ER-HM650 is completely dead. No output. The surge side is OK, but no output...
(More)
The backup side of my ER-HM650 is completely dead. No output. The surge side is OK, but no output from the other.
my 600VA Microtek inverter is delvering Battery back-up supply instead of main supply when inverter...
(More)
my 600VA Microtek inverter is delvering Battery back-up supply instead of main supply when inverter switch is made ON.
