Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
Kenmore model 116 25615506
Won't turn off, took hose off and still runs without shut off switch on hose???
  • Anonymous Nov 28, 2007
    I have the same problem! The vacumm won't turn off and the switch does nothing. Time to look for a replacement.
  • 3 Answers
The "vacuum won't shut off" problem is caused by a faulty triac (electronic component) on the P.C.B. assembly. You have two choices, depending on your handiness:
  1. Easiest: Replace the PCB: P.N.=KC86WBZRZ000
  2. More difficult: Replace the triac: P.N.=BTA16-600CW (ST Microelectronics): http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00002265.pdf
The PCB costs about $25.00 from Sears, whereas the triac costs about $1.50. Sears will not sell the triac - you'll have to find an electronics parts supplier.
You can sometimes find the PCB from a 3rd-party supplier. For example, this one on EBay: Mel-Co KC86WBZRZ000
Posted on Apr 01, 2011
What is the "PCB assembly"?
Posted on Dec 19, 2011
That did the trick! 6 bucks for the part + S&H. Thanks!!!
Posted on Jan 21, 2008
Almost certainly a blown triac on the circuit board in the canister - kenmore part number KC86WBZRZ000
Looks like a common fault with this particular model judging by the number of complaints on the web.
-Skip
Posted on Dec 12, 2007
Kenmore Progressive Vacuum electrical issue. My
It could be the wires or switch in the hose and/or the connection between the hose and the vacuum. It could be the power cord or a loose or bad wire inside the canister. It could be the carbon brushes in the motor are worn out. To find a short or electrical problem you need to know how to trace the power flow from the plug and cord all the way to the motor. You can test the wiring in the hose with an electrical tester to see if there is a problem with it before you purchase a new one.
Mar 08, 2017 | Kenmore Vacuums
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Hoover Model SH80520 starts and won't quit
that's how it's supposed to operate, switch on turns the unit on. switch off turns the unit off. thier is a wire that is connected to the leads on each outlet that turns the unit on when the hose is inserted and the switch is in the off position.
Mar 30, 2012 | Vacuums
I have a Kenmore "Intuition"
I had a different vacuum that did this. I took all manner of things apart looking for blockages and the like .I found that by having the vacuum handle in the full upright position shuts off the suction to this area and doesn't power the brush BY DESIGN. I think this is to get more suction to the hose.
Dec 18, 2017 | Kenmore 25512/ 25513 Progressive Canister...
Was using kenmore whispertone stopped suddenly disconnected brush unit will not switch on ????
if you took the hose out of the wand assembly then it may not turn on as the hose handle has a power button on it and must be connected to turn on the unit.Also check the powerhead for a reset button (small red / or black button on the back of the head){back of head not the bottom}
Oct 05, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Vacuum will not shut off
Sounds like you have wires crossed at the switch. The 2 wires coming in go to the center posts, 2 to the power head & 2 to the main motor.
Jan 31, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Bosch BSA2222UC canister vacuum shuts off after 5 minutes
You have a plugged vacuum indicator port. There will be a tiny hole somewhere near the hose inlet. Just clean it with a dry toothbrush. This will allow the vacuum pressure to equalize on either side of the shut off switch.
Jan 03, 2009 | Bosch BSA2222UC Compact Plus Bagged...
Kenmore canister switch issue
It most likely is the hose pcb. It has the switch on it, and part of it is either just dirty or bad.
May 17, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
929 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
