Original Audiolab 800M amp.Mains on light shows but not functioning.
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
K8m-800m motherboard manual
The manufacturer, First International Computer, Inc., has the manual on their ftp site. The direct link is: ftp://ftp.fic.com.tw/motherboard/manual/socket754/k8m-800t/25-11110-00.pdf . Google K8M-800M manual in the future in case the link changes.
I hope this helps.
Apr 04, 2016 | Intel EMACHINES K8M-800M / K8M800M VIA...
Why does my Audiolab 8000s mute light stay on?
Your amp is probably in Protect Mode, meaning you have DC Offset( a damaged amplifier). That will have to be repaired, before you can switch the unit on. If you need more assistance, or would like to inquire about repairing it, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
May 30, 2014 | NAD C372 Amplifier
Need user Manual for Audiolab 8000 A Amplifier
http://www.hifiengine.com/manual_library/audiolab/8000a.shtml
Try this...sign up first (free)
Feb 12, 2014 | Audio Players & Recorders
Audiolab 8000 Amplifier User manual/ instructions/Pdf
you could try a website called manualslib.com They have a wide range of manuals etc. for a wide range of car audio makers/models.
Feb 12, 2014 | NAD C325BEE Amplifier
RC-800M Remote Control
Are you trying to use the Insignia RC-800M to control a TV or some other JVC device? How old is the JVC product? Most universal remotes won't control a device that was built within 6 months of when the remote was programmed. (Newer devices will not work at all with an older remote.)
The RC-800M code for a JVC TV is 11601. For a JVC set-top box try the codes: 00775 or 01775. For a JVC DVD or Blu-ray player, try 32365. The manuals for most of the Insignia devices which came with the RC-800M remote are available from the Insignia support site: http://www.insigniaproducts.com/support.html .
I hope this helps.
Oct 01, 2013 | Insignia RC-800M Remote Control
Can i drive 4ohm speakers with an audiolab 800A amp
You can, but you will need to be carefull not to turn the amp up too loud, as it will overload the amp. It would be best to use 8 ohm speakers.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Aug 18, 2010 | ATI Audio Players & Recorders
Buzzing Audiolab 8000M/8000C set up
make sure ur mains supply and ur equipments are compatible. check all connections and most important make sure u have proper earthing.
May 02, 2010 | Audio Players & Recorders
Audiolab 8000CD Player Problem
This may be a problem with the sled motor. This is the motor that moves the optical assembly in and out along a rail. Try openint up the unit and cleaning off the rail with a dry cotton swab. Be careful not the leave any fibers on the rails. Also, while you are in there, clean the lens using another cotton swab and alcohol. Report back with your results.
Dan
Mar 28, 2008 | Audio Players & Recorders
79 people viewed this question
 Grubhead
Grubhead
