Question about Frigidaire Dryers
Frigidaire FDE336RES2 Hi I have an old dryer and just fixed a squeeking problem. As we were putting the dryer back together we found these 2 yellow plastic pieces and we know that one goes in the front of the dryer cabinet, but cant find where the other one goes. When we were taking it apart the one we know where it goes was still attatched, but the other was lying on the bottom of the dryer. I have searched diagrams and can't for the life of me find where the other one goes. I am assuming that because we did not put it back in that it is the reason for the grinding/rubbing sound we are now hearing instead of the screatching scream we were hearing. Anyone have any ideas on where to put this thing. I have some, but will keep them to myself!
Open the motor cover hole on the back of the dryer and right above the hole to the right side is a yellow plastic gear like mounted to the back plate of the dryer
Posted on Nov 20, 2008
Trying to replace heating element in my frigidaire dryer model# fde336res2. where is the darn element? thanx kevin
Hi awc9859...
Your heating element is behind the drum where it is attached and case of the dryer
I have also attached a link so you could view the part in its location...double click on the drawing and look for part 15.
Please take time to rate me thumbs up
http://www.partselect.com/PS418120-Frigidaire-131553900-Heating-Element-Assembly.htm?SourceCode=5&ModelNum=fde336
Sep 10, 2011 | Frigidaire Dryers
Frigidaire model FDE336RES2 makes a squealing noise and won't turn with a full load in dryer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Frigidaire Dryers
Frideraire dryer model fde336res2 won't eat. The
Take a look at #36 in the breakdown I have attached. This part is called a thermal limiter and blows if the heat is restricted in any way to cause the dryer to get too hot. You need to make sure that you don't have a lint buildup around the motor and in your vent hose. The part number for this part is 530320912. Hope this helps.250
Nov 19, 2009 | Frigidaire Dryers
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
Dryer will not heat up
check that you didnt disturb any wireing by mistake. then chec the contunity on your heating element. they are actually pretty fragile.
Apr 25, 2009 | Frigidaire FDE336RE Dryer
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
Dryer wont start
its one of three things, check your thermal fuse on the back inside of the vent, the door switch or the start switch
Jan 29, 2009 | Frigidaire FDE336RE Dryer
Need to know how to replace the belt on my dryer
Take off front and put belt over drum. Reinstall front. Take small access panel off back to install belt on motor. Idler pulley pushes against belt to tension it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Frigidaire FDE336RE Dryer
Broken tumbler belt
Slide a putty knife or other thin object between the top and front panels a couple inches in from either side. Press in and release the two spring clips holding the top panel and at the same time lift it up and lean it back. Remove the screws inside the front corners holding the front panel on. Place the new belt around the drum in about the same position as the old one was. Remove the lower rear panel to access pulleys. place belt around the motor pulley. Stretch the idler arm over and place belt around pulley. Reassemble.
Jan 03, 2008 | Frigidaire FDE336RE Dryer
Wiring diagram
check this and see if this helps you out http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1428&modelDesc=FRIGIDAIRE/FS%20DRYER%20-%20P5995326211&modelNumber=FDE336RES2&documentID=Y2705791&documentTypeID=PLDM&documentClassCode=PM&titleType=131850300%20WIRING%20DIAGRAM&titleID=00006&
Oct 08, 2007 | Frigidaire FDE336RE Dryer
Dryers Logo
176 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
