Question about Kyocera Office Equipment & Supplies
0x3101 error on kyocera when trying to send scan to email
0x3101 error when testing the send to email function
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
You can not scan usb, it has to scan via network cable via the scan card . you can use quicksetup utility to log in to the scan card and change the destination ip address of your tower. as long as your tower has a static IP sddress , should be applied via web interface of the scan card..
Posted on Nov 30, 2014
5 Suggested Answers
SOURCE: Bizhub 350 error code EA3226 when trying to scan to email
I changed the SMTP address from a name to an IP and that resolved it for me.
Posted on May 28, 2008
SOURCE: brother 5460cn won't scan to email,file,ocr,image
i have the same problem and it was resolved after downloading the control center updater.
here the link
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/003100/dlf003176.html?reg=us&c=us&lang=en&prod=dcp130c_all&type2=2&os=7&flang=8&dlid=dlf003176
Posted on Nov 20, 2007
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
shawn38
  • 200 Answers
SOURCE: We have a Kyocera FS1118.
I have the setup instructions posted, click on the link below and follow those instructions. If after following those instructions you are still having a problem feel free to contact me.
http://gfbm.net/selfhelp_kmacopier_scan_to_email_setup_command_center.htm
Posted on Jan 22, 2011
Error type: connect
smb scanning? check to make sure host ip is conrrect as well as long in info and path to folder /email make sure smtp server address is correct along with login info and try port 587 if its set on 25 comcast tends to block 25 for smtp scanning
Jul 09, 2014 | Kyocera FS-1128MFP FS-1128MFP...
When i scan to email, i get an error; "send error 2202" and the document is not sent to email. The Kyocera fs-1028mfp printer is connected to the LAN using a network cable.
Apparently there is a communication error between the printer mail server. Can you ping both reliably ? Is it an internal mail server ? If yes, can you ping the printer from it ? Did you try changing the network cable ? How about IP addresses ? Could there be a conflict ?
Cheers,
Franck Horlaville TAM Software
Sep 12, 2011 | Kyocera FS-1118 Printer
Km-3035 (kyocera) send email from scanner key, eveything seems to go fine, but no one gets emails, going into history of sending I find error E022. manual is no good, it give no codes. searched google, no...
The E022 error indicates -
The mail contained an e-mail address that the SMTP server can not find.
Check to make sure that the destination e-mail address was entered correctly.
The link below will take you to the manufactures web page where you can download the Scan System Operation Guide (Function Edition which list the error codes.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11796&rid=14242
If you continue to have a problem you can go to www.gfbm.net for more assistance, also they have some Kyocera setup and troubleshooting information.
I hope this is helpful,
Shawn
Feb 24, 2011 | Kyocera Mita KM-3035 All-In-One Laser...
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
CS-1820 Send function not working. Error Occurred; Results "NG"
Upgrade the firmware and the diver software, that will help you to fix the problem.
Jul 20, 2010 | Kyocera Copystar CS-1820 Black and White...
Code error 1102
The 1102 error code means that the login user name is incorrect or the domain name has not been entered. You may need to reneter the login user name, domain name and password.
Jun 07, 2010 | Kyocera FS-1118MFP Laser Printer
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
Transmit/Receive Error (0x3101)
i have the same issue, how did you solved it?
Apr 16, 2008 | Kyocera Office Equipment & Supplies
12,512 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
