Question about Orion VR213 VHS VCR
Vcr picture problem
VCR Model #VR0220 seems to have picture disappearing problem at times which mystifies me.
I have a motorola 40 hour hd dvr recorder box from comcast cable hooked into the vcr's atenna in jack and the vcr's output cable hooked to my tv..
checked the tv anbd its not the tv it self it seems that when the picture disappears i do have sound and when i turn off and on the vcr the picture comes back but then can stay a while or disappear again with no warning..
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Clean the heads. check out my tip
Posted on Jul 18, 2010
Digital programing
By the look of it you would need to connect a digital set box to it to record any TV programs, seeing that most countries are switching off or have switched off analogue TV. The video would then pass any signal it had recorded via a scart lead to any TV with one of those sockets.
Feb 11, 2014 | Orion VR0220 VCR
How do i hook-up my vcr to my cable dvr to record saved shows
In order to record from VCR to DVR You need to connect "VCR audio/video output RCA jacks " to" DVR 's Audio / Video Input RCA jacks.. ..
use either "RCA analog (red/white+ yellow ) " or "optic " cable.(any standard optical cable )..if exist .optic is the best way to connect it..Remember your VCR 's "OUT" goes into" IN "of DVR ..
pls also remember,wherever you connect your VCR on your DVR ,you should switch the source selector accordingly to correspond to the connection on the back...
Now you can record anything on DVR which played in VCR ..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Motorola Televison & Video
My cable tv service technician stopped by today to check on the reason as to why I was receiving prolonged and intermittent snowy reception on my DVR Motorola DCT3416 I. He consulted with his lead...
Seems logical to disconnect and remove the VCR and plug the cable right into the tv.
If the problem still persists after unplugging the power cord to the VCR and running the coax cable straight into the tv, then you know the VCR has nothing to do with the problem.
It is important to unplug the power cord to the VCR to test this and not just switch it off since it might be some kind of electrical interference generated by the VCR whenever it's plugged in.
If it's the DVR then I guess exchanging it for a new one is your only choice.
Good luck.
Feb 04, 2011 | Televison & Video
Vcr only plays sound, what's wrong ?
Try cleaning the video head with Servisol Video 40 see image:
Feb 26, 2010 | Orion VR0220 VCR
Using FIOS HD DRV STB with a VCR
Okay let me make sure I understand.. Looking at the back of your STB and VCR do you see an (IN) and (OUT) coxial connection?
If so, you can use the coxial connections to obtain your desired results.
I hope this solution is helpful. Please remember to rate thsi solution.
Feb 12, 2009 | Televison & Video
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Jan 15, 2009 | Proscan PSVR73 VHS VCR
New TV hookup
Erica,
You should have no problem with this. I have provided a picture of your model below for clarification. One end of the coax will attach to the 3-4 OUT on the back of the receiver and the other end will go to the NEW tv's coax input. If your set has two coax inputs you may have to select the port that you connect to in the menu portion of the tv. If the new tv does not have a coax input you can use RCA jacks which are red/white and yellow and connect those to the TV 1 output on the back of the receiver and the other end to one of the inputs on the back of the tv- this will require you to select the input source you connect to again e.g AUDIO 1, AUDIO2 etc. If you have a VCR run the coax from the 3-4 on the back of the receiver to the antenna inon the back of the VCR -usually the top port, then run another coax from the output- bottom port to the coax input on your tv. I hope I have been of some assistance to you and Thanks for using Fix Ya. If I can assist you further please let me know.
Jim
Apr 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Recording
Coax out from box into cable in on VCR. Coax out from VCR to Cable in on TV. Set TV and VCR to ch 3. Put in blank tape. Start show on DVR and hit record on VCR. Hope that works for you.
Feb 07, 2008 | Arris DCT6200 DTV Receiver
Orion VR213 VHS VCR Logo
212 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
