Your problem description is too brief, but try the following:
- Check if your wifi is turned on (there should be a button on your laptop) - Check if your external wifi (usb stick, or whatever you have) is installed properly - Check your IP address, if its in the same IP-range as your router's - Check your gateway IP - If you have access reset your router
It should work so far by now, if not:
- Switch to roaming mode - Try to connect your laptop through an ethernet cable, if it works find out those settings (IP, gateway etc.) and use them with your wifi thing.
If this doesn't help, there is either a problem with your router or the network must be secured.
Upgraded from 9.04 to 9.10. After upgrade system failed to recognize the Blitzz wireless adapter or...
(More)
Upgraded from 9.04 to 9.10. After upgrade system failed to recognize the Blitzz wireless adapter or Blitzz USB wireless adapter that worked on 9.04. System doesn't recognize the hardware. Help!
Music looks to be playing but no sound, Volume is up and is not on mute.?????OPS is Ubuntu on IBM...
(More)
Music looks to be playing but no sound, Volume is up and is not on mute.?????OPS is Ubuntu on IBM Thinkpad 600
hi am having same audio problem in CQ40-144TU. Please let me know the solution asap....
(More)
hi am having same audio problem in CQ40-144TU. Please let me know the solution asap. pratheep.pratheeps@wipro.com
hello i am looking to setup raid 0 with the alternative install cd for ubuntu 8.10 i have foudn...
(More)
hello i am looking to setup raid 0 with the alternative install cd for ubuntu 8.10 i have foudn steps for raid 1 but i want to do raid 0
