Question about Toshiba Computers & Internet
I have a toshiba satellite 1900-803 - when I open up the memory compartment on the back I can only find 1 slot which I have alread used to upgrade the memory to 768 MB. Where is the 2nd slot so I can upgrade further to 1GB ?
    Novelist:
    Champion:
  • 226 Answers
The other memory socket is located underneath the keyboard. First, you have to prop up and remove the plastic, black colored cover strip (start by inserting a small, flat screwdriver underneath it using the "Windows" key as leverage); after that, remove the 2 screws holding the keyboard down, and lift up the keyboard and set it upside down on the palmrest. The memory socket is located at dead center.
Posted on Apr 10, 2010
  • 3 Answers
Maccstokie,
It is possible that the other memory slot is on the opposing board side, and already occupied by system default memory. It is also possible that the ram is also located by the wireless card port. Open each of the underside compartments and see if there is an additional memory port, Trial and error is the best approach.
Drumwar
Posted on Nov 02, 2008
How to replace RAM in Satellite M45-S165
http://www.irisvista.com/tech/laptops/ToshibaM45/Satellite_M45_disassembly_1.htm
You can click on any photo to enlarge it.
Step 3 photo shows the Memory Compartment.
Two ram memory (SO-DIMM) can be used. There are two ram memory slots.
1GB however, IS the largest amount for EACH slot.
Regards,
joecoolvette
Apr 14, 2012 | Toshiba Satellite M45-S165 Notebook
Can i buy and install my own memory upgrade? if so what are size and compatibility issues to avoid? thanks
Toshiba Satellite A135-S2356 has a maximum of 2GB which can be installed in the maximum 2 memory Slots in the memory compartment: 2 X 1GB PC2-4200 DDR2 SODIMM (200 pins) memory stick.
Note that in general, especially for older laptops, that you should not mix different size/brand of memory stick as the unit may even fail to boot or can behave erractically (reboots or system freezes).
Hope it helps.
Jul 14, 2010 | Toshiba Satellite A135-S2356 Notebook
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
Change RAM in Toshiba Satellite A75 notebook
The Toshiba Satellite A75 came with either 256megs or 512megs of NON-REMOVABLE RAM. You will be able to insert a 256meg, 512meg or 1024meg stick of RAM in the slot. There will only be ONE slot to put the memory into. The only other socket on that computer will be for a wi-fi card but you would not be able to stick memory into that slot. The type of memory you will need is DDR333, PC2700, 200 pin SODIMM, 2.5 volt sync.
Apr 05, 2009 | Toshiba Satellite A75-S209 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Memory upgrade
    The M45-S169 only has one available memory slot.
    (I'm confused about your post that states "M45-S265" in the head line).
    • Configured with 512MB DDR SDRAM (both memory slots may be occupied)
    • 512MB(min)/2048MB (max), 256MB on-board memory with 1 available memory slot for 256MB, 512MB, or 1024MB PC2700 DDR 333MHz SDRAM 2.5V SODIMM memory modules
    You can find the complete specifications here.
    Jan 05, 2009 | Toshiba Satellite M45-S265 Notebook
    Ram upgrade
    Its support "DDR SDRAM"
    Max Supported Ram is "1GB"/"1024 MB".
    Ram Speed: 266 Mhz..
    Good luck...
    regards,
    Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
    Hard drive and memory
    the laptop should pick up a 20gb or 60gb ide hard drive with no problem
    Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
    Computers & Internet Logo
    70 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
