I have ths problem, my husband gave me automatic washing machine that he bought at Kuwait. the product name is ALGOR. Since it is second hand, No manual was given to him. I dont know why its always in washing process. I waited to drain the water from the hose but i failed. It ended up wet and the water is still inside the washing machine. pls help me
please rotate the knob at number 6 and then start the machine you will get clothes duly washed and wrinsed.please rotate the knob at number 6 and then start the machine you will get clothes duly washed and wrinsed.
You can't post conmments that contain an email address.
Good Day, Your washing machine is fully automatic? the washing cycle is normal? if yes do the same maybe it will help you. for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise. Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up. if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck, if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Remove
if
water stuck,
if
Good Day, Your
the
if yes
for
Remove
if
water stuck,
if the
Good Day, Your
the
if yes
for
Remove
if
water stuck,
if the
Good Day, Your
the
if yes
for
Remove
if
water stuck,
if the
Good Day, Your
the
if yes
for
Remove
if
water stuck,
if the
perhaps not in that hose but in the pump housing just below it, quite possible that someting is jamming the imopellar preventing proper draining of water
