Question about Bosch Refrigerators
KGU3200GB, Freezer working normally but there is a build up of ice inside on floor which eventually leads to water on floor
  • 59 Answers
Behind the evaporator cover on the inside of the unit is a small drain hole that is either clogged or frozen over. First clear away the ice with some hot water or a steam cleaner to expose the drain. Next try pouring hot water down the drain, if its clogged you can usually clear it with high pressure steam or by removing the drain tube, which you can get to from the back under the unit. If all it is is frozen over the a 14 gauge wire wrapped around the heater and extended into the drain hole a few inches should solve you problem. Good Luck!
Posted on Nov 02, 2008
  • 1,122 Answers
You have a clooged drain,something has gotten in it and it has frozen over,if it is a sxs the drain is in the bottom middle of freezer,you can use a hair dryer to melt ice ice then i mwtal hanger to clear it out,let me know how you do-mike
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Water is appearing under the front left foot (as you look at it). It builds up in to puddle over night. I have checked the instructions which are difficult to follow (not very clear English) but it said...
Freezer drain is plugged.
Two solutions:
1. Call a service repair company.
2. Turn off both controls (turn to lowest setting) and open freezer door for minimum of 24 hours (max 48 hours). That will thaw drain sufficiently.
What has happened: Somehow the freezer drain had ice build-up and eventually froze solid. Every time the unit went into defrost mode, the melted frost (now water) had no place to go. The normal exit is the freezer drain hole which leads to the drip pan underneath. That exit is plugged with ice, so the water went where it could - across the freezer floor and out the bottom of the freezer door. You found it and wondered why.
Mar 20, 2011 | AEG S75348KG Bottom Freezer Refrigerator
GE side by side leaks water from icemaker tube
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice build up on floor of freezer drawer starting under ice maker
since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
Feb 08, 2009 | LG LRFC25750 Refrigerator French Door
Ice build up
Same repair as water leak on floor. unplug, remove back inside panel of freezer, clean out drain hole.
Jan 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Open Questions:
Bosch Fridge Freezer Model kan60a45g - Water Dispenser is not working, only a tiny dribble!! I've proven water flow to the egress / exit of the water tank... I have a Bosch American Style Fridge Freezer Model kan60a45g. The water flow out of the built in dispenser has gone from perfectly fine to a tiny dribble, it was gradual and I assumed it was the filter needing to be replaced. However replacing the filter seemed to make it worse, so I replaced filter with the plug in order to remove it from the equation. It still didn't work, so I went to the beginning of the flow and confirmed the pressure / flow into the "in pipe" was fine. I then checked flow to and from the filter unit, again fine. Down now to the inlet valve (I think it is called) and I checked all the valves worked here when required - they do. Next I checked the flow at the point of entering the water tank which sits in the fridge. It seems fine. I removed and flushed the tank and confirmed there are no problems with its flow when refitted. So sadly it seems the problem is somewhere between the exit of the water tank and the outlet in the freezer door itself. Everything else is checked out. I cannot see how the pipework runs from the fridge side into the freezer section and then up through the hinge of the freezer door. Does anyone have any suggestions? Ideally I suppose I would remove and replace the pipe - it has to be blocked somewhere I guess? Could I blast with compressed air? If anyone has experience of this issue, or knowledge of how to remove this last bit of pipe work then I would be very grateful. Thanks in advance!
Mar 01, 2018 | Bosch Refrigerators
Refrigerators Logo
179 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
