Question about GE VG4054 VCR
VCR shows "PLAY" on machine but doesn't show on TV
When putting a tape in VCR, the front of machine shows PLAY but nothing will show on TV screen. All lights seem to be working and can hear tape running but does not "connect" to TV screen. Have a remote but not a manual. Seems like I'm just missing pushing one button somewhere to make it work?? Thank you!!
  • Anonymous Mar 17, 2014
    tv will not show picture but vcr does work
    Problem Solver:
  • 7 Answers
Did you try pressing the TV/VCR button?
Posted on Feb 13, 2009
    Brigadier General:
  • 6,966 Answers
If even the sound aside from the video is not reproduced on the TV, then your description "connect" indicates that the TV is not set to receive the audio/video signals from the VCR. Initially, pls try:
  • set the TV to Channel 3 (or 4); or
  • set the TV to A/V, Video 1 or Aux 1.
Additionally, you need to confirm how the VCR is hooked to the TV unit, bu a single coaxial cable or 3 cables with RCA connectors (yellow, red & white).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 02, 2008
SOURCE:
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
Had to get rf modulator and still cannot operate vcr will play but will not show tv shows followed dicections on connections but no results
RF modulators are designed to work on specific channels. ex: 03 & 04
Make sure your TV is set to that channel.
Also the VCR has the option to display live TV or VCR.
If you cant find how to switch to VCR usually putting in a tape and pressing play will automatically switch it on. Then you can see the VCR on the TV.
Aug 08, 2011 | Televison & Video
My VCR won't play my movies! The tapes are fine its just when I put the tape in it just shows a scraggly screen. Everything is plugged in but my movies won't play. What do I do?
If the vcr is running the tape, your video head is probably dirty, try using a cleaning tape if you have one. The second option is use a brand new blank tape T120 and set the the machine to sp speed (2hr running time) and let the tape run the full course. The third option is to remove the lid of the vcr and carefully clean the video head with a swab dipped in rubbing alcohol rotating the head by hand as you proceed allowing several minutes to dry before loading your tape.
Dec 21, 2010 | Sharp VC-H810U VHS VCR
Recording instructions
well if the vcr is hooked up and you can watch a show on it put in a tape that has a movie on it then press play if you can see the show take out that tape put in your blank tape find the show on your tv u wish to record press record try this before the show comes on record a little bit of a show like 30 sec or so then rewind and play back to see if it did record if it did just repete this when the show that you want to record comes on hope this is helpfull....
May 30, 2010 | Panasonic AG-DV2000 Mini DV VCR
I insert a tape to play and I can tell from the front panel that it is playing, but does not show up on the screen. Everything seems to be working fine, I just don't know why the tape does not show on the...
Make sure your cables are on the out jacks of the vcr to the in jacks on the tv. Also, you will have to make sure that you have selected the proper external input on your tv to where your vcr is hooked up. Example: If it is hooked up to video one on your tv then you have to select video one on the tv when watching your vcr. I hope this helped.....
Nov 08, 2009 | Samsung Televison & Video
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
VCR records TV shows, but doesn't play them on other VCR's
The machines playabilty setting has gone off. take to nearest repair shop and they will probably reset or change guide posts.
These components normally will allow a tape recorded in one machine to play on another. Had many of those esp from camcorder to vcr
May 05, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Recording on a Panasonic VCR
This problem is undoubtably dirty or worn video heads. Try using a good quality head cleaning tape. If this fails, re-post, and I will explain how to clean heads by hand.
Dave Duff
Mar 01, 2008 | Panasonic PV-V4022 VHS VCR
VCR Tape will not play, it keeps ejecting
I have a similar problem. It takes 3 or 4 times to get my Sony VCR to accept a tape. Once it does, everything is fine, until I turn it off. Next day, same trouble. I tried several tapes and brand new tapes. No difference. I have opened the cabinet and used alcohol to clean various stuff, no change.
Feb 02, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
Flashing '2' or '1' or '4' when I try and play a tape
The idler on your machine needs to be changed and also the drum head of your machine needs to be clean.tape head cleaners can be bought from any electronic shop.the idler must be changed by qualified techn
Jan 22, 2007 | Philips VR540 VHS VCR
Televison & Video Logo
203 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
