Question about Samsung RS2578BB Side by Side Refrigerator
Samsung RS2577SL not cooling
We had some noise (low whining) from fridge occassionally. We called BB service guy during the tail end if the warranty. HE checked and said no problems detected. Put a surge protector $4 on the mains outlet. Now a month later and perhaps no coincidence, the temp does not cool. We tried resetting the fridge and ofcourse removing the surge protector to no avail. The solenoid or relay can be heard to click when the demand for cooling comes from the electronics, and the front panel seems to function fine, just when you expect for the compressor to come on there is nothing. Compressor model : MK183C-L2U.
Your help is greatly appreciated.
Thanks
Farshad
SOURCE: Samsung RS2555SL humming noise
the freezer has gone on to test mode for some reason press and hold down at the same time the power cool and power freeze buttons for 8 seconds this will take it off its test cycle
good luck
phil
Posted on Mar 30, 2008
tborn6
  • 700 Answers
SOURCE: MK183C/L2U compressor making noise
take and look at the condenser fan in the back of the unit and make sure that its working properly. If the noise is from the inside then yoiu will have to defrost the unit first.
Posted on Feb 04, 2009
  • 145 Answers
SOURCE: I have a Samsung side
I seen this problem before this fridge is different from others because has tow evaporators Must likely your defrost heating element on the fridge side burn out and is letting ice to build up on till touch the fan blade and start making that sound now The problem is than the defrost heater element is build on the evaporator So the options are discharge the system and emplace the evaporator or what I do is Carefully cut of the old heating element install a generic one and a defrost thermostat and a mechanical defrost timer (8-10 hours) drill a hole to the back of the fridge and run a line from the back and the timer next to the control boar tapping the main power lines Now unless you are familiar whit electrical wiring and the defrost system of older fridges I don?t recommend to tray. Even must technicians would not dare do make modifications to a existing system. If you can?t do some thing like this what a recommend is turn the ?POWER COLD? off and see if gets any better .
Posted on Jun 08, 2009
projdoc
  • 2237 Answers
SOURCE: samsung model rs2577sl. fridge side not working
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 26, 2009
  • 10 Answers
SOURCE: samsung SRS583HDP fridge not cooling. Side by side
Most likely the thermostat in the fridge, especially if it read 5 degrees until you reset it. Possibly the compressor in the fridge side as this fridge has twin cooling, or the circulating fan in the back of the fridge is frozen, which is a common problem as well.
Easiest things to try is to see if the fan is frozen and check if the fridge cooling is actually working. Turn off the fridge, remove the shelves, remove the 4 screws that hold in the bottom cover and the 2 screws that hold the water tank in. Cover should then come out a few inches. Reach behind and unplug the 2 plugs and pull out the cover. If the cover doesnt come out easily it may be glued to the back of the fridge by ice. Leave for a couple of hours and gently prize it off. Check for ice around the fan and that the fan spins freely. You could try sitting the cover inside the fridge, plug it in turn it back on for a few minutes (be careful) and then open the door and quickly look / listen to see if the fan is still spinning (it stops when you open the door). Leave the fridge off for a while until the ice disappears off the coils. Turn back on for half an hour. The coils should be icy again. Anything else call Samsung. If the deal in your country is the same as mine the fridge has a 2 year warranty but in the fine print the sealed compressor unit has five years on parts only. You could get the unit replaced for labour costs only. Check your warranty card.
Posted on May 05, 2011
Why is the rear end making a whining noise
The whining noise could be for many reasons. Narrowing the possibilities depends on when the noise occurs. If it happens only while decelerating at any or all speeds is most likely caused by bad pinion bearings or loose pinion bearing preload. If it happens during acceleration over a small or large speed range is usually caused by worn ring and pinion gears.
One cheap thing to check is the fluid level in the differential. If low, topping off the lube may help for a while.
Jun 12, 2014 | 2000 Ford Mustang
Engine whine, low howl from under car, rear end noise
well i dont know about the howl but i would definitely get the rotors resurfaced they are not supposed to stop at one point if the tire is in the air and spin it by hand the tire should come to a smooth slow stop and bearings are very tricky to spot i would replace them just to be on the safe side
Apr 07, 2017 | 2013 Hyundai Sonata GLS
Samsung srs2028cvw fridge freezer noise
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 11, 2012 | Refrigerators
Defrost heater do not defrost creating poor air circulation
for starter call viking with your mod and ser #
there is a hinge recall on fridge door is covered by warranty regardless of age
it can cause the air channel from freezer to fridge to ice over due to too much humidity entering fridge
this stops cooling in fridge
the viking warranty starts from the day you took possession
defrost heater almost never
sounds like you need a better servicer
ask viking for other auth servicer in your area
gl
Apr 07, 2017 | Viking DFBB363L (20.3 cu. ft.)...
When I get up to about 65-70 mph with my 2004 Lincoln Navigator it makes a humming noise... very annoying.. Can anyone help me with what this is and how I can get it fixed?
Unfortunately, this is a somewhat common problem. Ford has issued several Technical Service Bulletins related to rear end noise. Without an extended warranty, this is something you will have to pay for.
TSB 05-23-3 11/28/05 REAR AXLE NOISE REPAIR FORD: 1997-2005 Expedition, F-150 2002-2005 Explorer LINCOLN: 1998-2005 Navigator 2003-2005 Aviator MERCURY: 2002-2005 Mountaineer
ISSUE:
Some vehicles may exhibit an axle whine or hum during acceleration, deceleration and/or cruise.
ACTION: An axle repair kit has been developed which incorporates most parts required for a comprehensive axle repair. The kit should be used instead of installing a complete axle assembly to repair an axle whine/hum. Replace Ring and Pinion with Axle Kit and Components.
Mar 20, 2011 | 2004 Lincoln Navigator
Massive noise on my samsung fridge freezer
samsung fridge freezer problems
check this guy out on youtube
Dec 29, 2010 | Freezers
Samsung RS2577SL FREZER COOLING REFRIGERATOR NOT COOLING
The most common cause of this problem is that the dampers in the ducts from the freezer to the fridge are stuck in a closed position. Ensure that the dampers are working correctly, and that the evap coil is not iced up. If it is this is a sign of a bad defrost timer or defrost element (timer is more likely). Hope this helps
Jul 23, 2010 | Amana DRT1802B Top Freezer Refrigerator
Samsung RS2578BB Side by Side Refrigerator Logo
380 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
